» ecotec swap
Yesterday at 3:53 pm by Hotrodz of Dallas
» New 944 widebody & aero
» Wilwood MC on it's side
» V8 Conversion Parts
» Fuel pump options
» Poly engine mounts melted
» JP's LS1 Conversion
March 2018
MPG and what are you running
Post  bp944 on Wed Jun 09, 2010 8:33 pm
I'm looking at running an built up ls6 into a 944 turbo. But I'm hesitant to go with that high CR since my wallet is all going to tuition. I know there's a price difference between ls6 and ls1 heads but I have access to both. I'm just curious what you guys are running and what mpg you're getting. The ls1 forums have heavier cars to begin with, so their mpg is basically useless.
Re: MPG and what are you running
Post  cfgioja on Wed Jun 09, 2010 10:10 pm
I am not sure on the difference between them. I am still in the process of fixing my once running ls1 948 and putting ls6 heads on it. I will keep an eye open for you.
Post  Porch on Thu Jun 10, 2010 8:58 am
Sounds like a bad project to start if you're still in school, but that's my .02! Smile
I get ~23mpg with a mild cam and an otherwise stock LS1. My cam is bigger than the LS6 cam. So you can probably expect ~25mpg with an LS6?
Significantly worse if you get on the freeway. I have the N/A 5th gear and much larger rear tires to put the v8 at a more comfortable cruise speed.
