Tach reads low
Tach reads low
I have an LS1 with a MEFI4a ECU in a 1987 944S(951) that I recently purchased. The conversion was done about nine years ago.
I have been told that the tachometer output from the MEFI4a ECU is the same as for a "standard" GM ECU on an LS1; 5 volt square wave with frequency dependent on engine speed. I believe that the ECU tachometer output is connected directly to the original Porsche tach. From research on this forum, it seems that this should work correctly. However, when the rev limiter of the ECU kicks in at a nominal 6000 RPM, the tach is only reading about 4600.
Has anyone else has run into a similar problem?
JohnG- Posts : 8
Re: Tach reads low
My tach does not read low. It is not connected to the back of the tach. Have you checked this connection? Mine is connected to the tach wire that connected to the original DME. I forget the color of the wire.
