Tach Resistor Mod
Tach Resistor Mod
Does this mod work on the 85.5 and later Tachs?
http://www.porschehybrids.com/php/viewtopic.php?f=2&t=1819&st=0&sk=t&sd=a&hilit=tach+mod
Re: Tach Resistor Mod
Hey XS, it's my understanding that the LS computers already give off a 4cyl tach signal so you shouldn't need to modify anything. You should be able to splice into the connector by the DME that goes to the dash for tach signal a d run it right to the PCM.
MARK
MARK
Marky522- Posts : 175
i'd still like to know regardless of the fact, because this is something that i'd do with my tach
v8944- Posts : 211
That statement is an urban myth, at least with the 5.3l truck pcm....or my engine can do 12,000 RPM.
I want to do the mod so I can say that I have done it all when it comes to a sleeper swap. Other than the 2 digital gauges in the console spot, I want a factory clean look everywhere else. No Big tachs on the dash here...that's more "mullet" than sticking in the V8.
Smoked a Rustang going to pick up milk earlier....Second gear launches aren't too bad, the 5.3 pulls it like nuthin'
You can leave the tach alone and use as many coil signals as you need to fire the tach. Mine is a wasted spark so I used 2 coil inputs into the tach to equate the 4 firing pulses I need. I don't know what the LS computer gives off however this is another option for making the tach read properly without having to buy a $90.00 box or taking your dash apart, Just need some diodes!
http://www.megamanual.com/ms2/EDIS_tach.gif
Wild Bill- Posts : 121
