944Hybrids
Welcome to our forum.
LS1 Tach mod
Page 1 of 2 • Share •
Page 1 of 2 • 1, 2
LS1 Tach mod
Curious, People have figured out the LT1 tach mod.
Does anyone have a way of modifying a Tach for a LS1/LS6 motor?
cfgioja- Posts: 751
Re: LS1 Tach mod
Step 1: Strip 944 tach wire
Step 2: Twist wire together with LS computer tach output
Step 3: Cover with electrical tape
Step 4: Drive.
Step 4: Drive.
Porch- Posts: 770
Re: LS1 Tach mod
Solder too maybe?
Re: LS1 Tach mod
there is nothing else to it? I was under the impression the tach need modifying too for an ls1. Guess I need to keep up with you guys alittle more.
cfgioja- Posts: 751
Re: LS1 Tach mod
Back on this subject as I will be putting my dash back together. Which wire on the cluster is the tach wire? I have a wire from my PCM that says tach, I just need to hook it to the right wire on the car now.
cfgioja- Posts: 751
Re: LS1 Tach mod
Anybody know what wire to splice into for the tach. I have the cluster out and am looking through the chilton, any help would be nice.
cfgioja- Posts: 751
Re: LS1 Tach mod
for the late dash cluster, looks like plug "B" pin 3 GN/BK...is the tach input.
it comes from an 8 pin connector by the original DME (with 3 pins wired/used) pin # 2
at least per the schematics.
probably just a pulsing ‘ground’
surprised nobody with better knowledge has jumped in yet.
944convert- Posts: 58
85.5 is Easy
xschop- Posts: 2073
Re: LS1 Tach mod
I know there was a post out there some where but it didnt pull up when searching for it, thanks guys.
cfgioja- Posts: 751
Re: LS1 Tach mod
I hooked up the wire and my tach works but I wonder about the accuracy of it. At idle like a chopper bike it says it is running a 2k. I doubt that very much But it revs up as I hit the gas and when I put it in first the speedo started kicking up alittle. Since it is still on stands I didnt want to go crazy with it.
cfgioja- Posts: 751
Re: LS1 Tach mod
Has your computer been monkeyed with? Stock, the computer outputs a 4-cylinder tach signal. If someone has modified the computer, they might have set it to output an 8-cylinder tach signal. That's what happened to xschop...
Glad it's running though!
Porch- Posts: 770
Re: LS1 Tach mod
It has been modified, I will ask John at speartech if that is what he did. Thanks for the info.
Thanks for the support too.
cfgioja- Posts: 751
Re: LS1 Tach mod
John Spears got back with me:
so when I go to get a dyno and tune run I can reset the tach signal right?
Collin,
1) 202 on, 197 off. (temp for primary fan)
2) Yes, Tach set to 8 cyl output.
3) No cam changes made to your PCM program. No cam specs provided. (figuring out if it needs a tune to match my new cam)
John
Speartech Fuel Injection Systems, Inc.
cfgioja- Posts: 751
Re: LS1 Tach mod
now I have to keep it under 3500 rpm so I dont break the Tach at 7k. lol
cfgioja- Posts: 751
Page 1 of 2 • 1, 2
Similar topics» Standard Instruments to Tach 1970 Mach 1
» tach wire hookup options
» why does my tach read 2x engine speed?
» LT1 TACH.... WHAT RESISTOR?
» Looking for an In-Dash Tic-tock Tach for my 1977 Chevelle Classic,
Page 1 of 2
» HELP . . . Electrical gremlin
» Rich's LS powered 944 track car
» First Time Swap 85 Porsche 944 to LS6
» Oil and steering cooler options
» selling conversion parts due to new baby
» Strut brace?
» What LS Exhaust Manifolds / Headers
» building a 1983 948 on a budget - pointers?
» To " badge or not to badge "
