Torque Tube Stuck
Torque Tube Stuck
Hello all I have a 87 auto 944 which I am prepping for my V8 conversion. So far the trans is out, the 9 bolts on the ring gear is out and the 4 bolts mating the torque tube to the engine bell housing also out. I still cannot get the shaft free. What am I missing?
crowstyle- Posts : 28
Re: Torque Tube Stuck
Did you rotate the TT 180o so that it can get past the torsion bar carrier?
I'm in the process of lowering the carrier for sufficient room. I hope this will be the fix to my delay. Will post results.
You don't need to lower the carrier to move the TT back, just rotate the TT 180o. You should then be able to pull the engine, work on the clutch, or whatever else needs to be done.
So I spin the TT 180 as directed, but the shaft is still tightly secured in the flywheel. So the case is actually sliding of the shaft since the shaft is not breaking free. Just to remind you, I am not using the Porsche trans nor TT for my build, it's all getting tost.Lemming wrote:You don't need to lower the carrier to move the TT back, just rotate the TT 180o. You should then be able to pull the engine, work on the clutch, or whatever else needs to be done.
So i finally figured it out. Below is the photos which shows what need
to be done at the engine BH area when removing the TT on an "auto" 944.
The is a dust cover on the driver's side on the BH. Remove it then you will see in that round opening a clevis tightly secured around the shaft. I used an 8mm Hex bit socket to undo it.
After loosening that clevis i still had to remove the BH. The above photo shows a round ring/spacer of some sort that has a snap clip in front of it. Remove clip with a pair of pliers and out came the shaft.
crowstyle wrote:So I spin the TT 180 as directed, but the shaft is still tightly secured in the flywheel. So the case is actually sliding of the shaft since the shaft is not breaking free. Just to remind you, I am not using the Porsche trans nor TT for my build, it's all getting tost.Lemming wrote:You don't need to lower the carrier to move the TT back, just rotate the TT 180o. You should then be able to pull the engine, work on the clutch, or whatever else needs to be done.
My bad, I did not catch the fact that you were running an auto.
Lemming wrote:crowstyle wrote:So I spin the TT 180 as directed, but the shaft is still tightly secured in the flywheel. So the case is actually sliding of the shaft since the shaft is not breaking free. Just to remind you, I am not using the Porsche trans nor TT for my build, it's all getting tost.Lemming wrote:You don't need to lower the carrier to move the TT back, just rotate the TT 180o. You should then be able to pull the engine, work on the clutch, or whatever else needs to be done.
No worries your help was appreciated.
