LQ9 6L swap
LQ9 6L swap
i was looking into getting a 2005 + escalade engine the LQ9 6L
i wanted to know if anyone have made this swap/ is possible to do it ?
i did a search and nothing came up im new so whats up!
matt889- Posts : 214
Re: LQ9 6L swap
shouldnt be much different than the other ls swaps. keep in mind being a truck engine you also need to change the accessory drive and intake manifold.
Re: LQ9 6L swap
i will still like an input of someone who wanted/did it ! just to know all the turns i might have to travel through!sharkey wrote:shouldnt be much different than the other ls swaps. keep in mind being a truck engine you also need to change the accessory drive and intake manifold.
Re: LQ9 6L swap
well, i cant help you there, but i do know the lq9 is just a high compression lq4, everything else is the same between them. externally, they are pretty much the same as the 4.8/5.3. engine mount locations are the same, flywheel, clutch, headers, starter, etc, all the same. if you can find info on a 4.8/5.3 of the same era as the lq9 it will be basicly the same
Re: LQ9 6L swap
Thank you that clarifys!
Today at 12:47 am by sharkey
