Swaying questions
Swaying questions
Popular upgrade to the stock NA cars is to stick on Turbo sways. Question is, since I stuck in the Ironbock 5.3l and dropped it 1"...will I need the thicker Turbo sway bar up front, rear, or both?
Also, are the bushing O.D.'s the same as the NA's? Because I know the I.D.'s match the respective bars.
Re: Swaying questions
What are you currently running for springs bars and shocks? I would think you may need to adjust for a touch more nose weight. maby a little more front spring and rear sway bar. How is the current setup reacting?
944ls- Posts : 24
