Wheel choices EmptyToday at 7:08 am by gwistrup
Wheel choices EmptyYesterday at 10:12 am by Nath1142
Wheel choices EmptyMon Apr 22, 2024 7:22 pm by lowform
Wheel choices EmptyMon Apr 22, 2024 7:12 pm by lowform
Wheel choices EmptyMon Apr 15, 2024 7:28 pm by JW1970
Wheel choices EmptyMon Apr 15, 2024 6:59 pm by JW1970
Wheel choices EmptyMon Apr 15, 2024 9:51 am by Raymond-P
Wheel choices EmptyFri Apr 12, 2024 3:07 pm by Rob44
Wheel choices EmptyWed Apr 10, 2024 10:09 pm by LS982
Wheel choices EmptyTue Apr 09, 2024 1:54 am by lowform
Wheel choices
Wheel choices Empty Wheel choices
Post  Oso Mon Apr 16, 2012 10:14 am
Going to pick up new wheels today and I wanted some opinions before so.
The wheels for sales are a set of 18"x10 square 993 hollow spoke twists for $525 or a set of 17"x9 rear/17x8front twists.
My question is, has anyone encountered any problems running 10" in the front. I dont had lindsey racing springs so I'm pretty sure it will clear.
Any opinions/concerns before 6pm eastern would be great.
Oso
Wheel choices Empty Re: Wheel choices
Post  Rich L. Mon Apr 16, 2012 12:43 pm
I haven't tried 10" wheels. My street setup is CupII 17x8 ET52 front and 17x9 ET55 rear. With 225 front and 255 rear street tires there's lots of room inside and out even if the fender lips are not rolled.
Post  shokwave30 Mon Apr 16, 2012 1:00 pm
that seems a little to wide for the front.. the back would be good. Im trying to figure out what wheels i want to.. i know its gonna be 18x10 rear 18x8 up front. just not sure what style i want.
shokwave30
shokwave30
Wheel choices Empty Front tires
Post  fliermike45 Mon Apr 16, 2012 5:00 pm
Rich, Have you changed your front end alignment with the 8" wheels? I have the same setup as you and my steering is twitchy, precise but has to be watched carefully on all but smooth roads.
I had this before the engine swap because I installed the cup1 wheels and tires first. I have checked the alignment and it is correct to the Porsche specs.
Had the same effect with the original Porsche PS pump, still the same feel with the Turn One pump.
Bump steer has been corrected for the 3/4" X-member drop.
Post  Rich L. Mon Apr 16, 2012 5:15 pm
fliermike45 wrote:Rich, Have you changed your front end alignment with the 8" wheels?
No, can't say that I have. It's zero toe in the front, -.02 total toe in the rear. But to be honest, I've driven the car on the street very little. It chases ruts big-time but I wouldn't call it twitchy. My track wheels are wider still, 8.5" with even less offset, and it's a manual rack. The thing is very eager to turn-in on the track with moderate understeer at the limit. I have the rear bar set to soft, will change that to reduce the understeer as I get comfy with the new engine power.
Wheel choices Empty Tires
Post  fliermike45 Mon Apr 16, 2012 5:29 pm
That describes it exactly.
Post  Rich L. Mon Apr 16, 2012 5:58 pm
Ah, well then I'm experiencing the same thing. I've noticed this on several cars when pushing the front contact patches farther apart with spacers or wheels of more negative offset. It sucks on the street but sure makes a car more eager to turn-in at the track. The m030 brakes made it even more noticable due to the 3mm wider hubs.
Post  docwyte Tue Apr 17, 2012 8:50 am
I run 17x9 ET55 Cup 2 wheels with 275's all the way round for the track. Don't have any issues with the car hunting ruts...
Post  Rich L. Tue Apr 17, 2012 11:24 am
Wow Doc. Did you have to do anything special to get that rubber in the front? I'll have to test fit a 9" cup2 w/ 255 up front. Seems like running square is the way to go.
Post  docwyte Tue Apr 17, 2012 11:56 am
Nope, fits perfectly. I'm running factory Turbo S front struts with 250lb springs and Racers Edge camber plates, -3 degrees.
Running square is awesome, saves me a TON in tire wear and costs...
Post  Oso Tue Apr 17, 2012 12:46 pm
docwyte wrote:I run 17x9 ET55 Cup 2 wheels with 275's all the way round for the track. Don't have any issues with the car hunting ruts...
Awesome news! I ended up buying the 10" square set since he wasn't ready to let go of his 17 track wheels.
He has 245 on front and 275 rears which I will be replacing for all 275's as soon as they need to be changed.
I'll report back on how they fit as soon as I get my car back.
Oso
Post  Rich L. Tue Apr 17, 2012 1:16 pm
What's the offset on those wheels? Looks like the 993 widebody rear 18x10 is ET65. If that's what you got, 10mm spacers are needed to match Doc's ET55 offset.
Post  Oso Tue Apr 17, 2012 1:22 pm
yea they are ET65. And I have an early 944 with stock stackable spacers... I got 6 spacers total that came with the wheels lol. I hope it fits ok.
I'm planning on get a set of custom wheels in the near future anyway, I just needed wheels to replace my cookie cutters which dont clear my new brakes.
I should have everything mounted and working in 2-3 weeks so I'm very excited to get my car going after 2.5 years doing this swap.
Oso
Post  docwyte Tue Apr 17, 2012 1:23 pm
Widebody offsets are an ET40, narrow body is ET65. I'm running 18x10 ET65 street wheels in the back and get a slight rub here and there, however I definitely couldn't fit them with a spacer, that would push them out past the outer fender lip.
