Largest tire size for 15 inch phone dials
I have a 5.3 swapped 944 in progress and was wondering what tire size can be run on the stock na phone dials. Other forums have covered this topic but the answers are very vague and the conversation usually goes off the specific topic. I do not want to run the stock tire size (215/60-15) as I suspect it would be a little sketchy with with double the horsepower and torque.
zach.wassman- Posts : 5
Re: Largest tire size for 15 inch phone dials
your wheels will be 15x7". you dont have much option for tire sizes that are larger. i think about your only option these days would be a 225/60-15. any wider will start getting into a range thats too wide for the wheel.
id look to some larger wheels. a 16" wheel will open up some tire size options, however id skip them and go to 17". i can say a 225/45r17 front and 255/40r17 works very well
smkn951 and zach.wassman like this post
Thanks for the advice I will have to look for a good deal.
choices
anyone know of a wheel that looks like phone dials in a 17" or so like the Autostrada Monza 17"that is Similar To Porsche Phone Dial Wheels but cheaper that can be found in wide sizes ? preferable an offset that has a deep dish ....
jerry944- Posts : 9
» Does a calculator exist to determine maximum wheel & tire size?
» Rim and tire size 91 944S2
» New phone number for TPC?
Today at 12:39 pm by Nath1142
