Help Identify this connector!!!
1986 944 Turbo
I took my dash out a year ago. I thought I would remember where everything went. I did pretty good but there is one connector that I just cant remember what it is used for.
Wires are black and green. It has two contacts on the back of it. It is located under instrument console and is hanging on the ignition side of the column.
Any thoughts?
Any thoughts?
Re: Help Identify this connector!!!
I looked and couldn't find it. Could it be the one that connects to the odometer reset?
There is a plug on the back side of the ignition switch, just to the side toward the steering wheel. It should be easy to get to if the instrument cluster is still out.
Looks like it went to one of the dash switches, the switch came apart and part of the switch is still in the connector.
Yep, it is on the back side of the igntion assembly between the steering column and the ignition switch.
(view is from underneath)
lets see if it will start now...
» Please help identify this connector
» Can you guys help me identify what this is for?
» Can anyone identify a Harmonic Balancer?
