Today at 12:20 pm by superman22x
» New 944 widebody & aero
» Oil Pan question
» 83' Porsche 944 LM7 Build
Can anyone identify a Harmonic Balancer?
Post  fliermike45 on Sun Mar 07, 2010 4:15 pm
Can anyone identify?
Has the following numbers:
NH1480 F73 2605
Re: Can anyone identify a Harmonic Balancer?
Post  944-LT1 on Sun Mar 07, 2010 4:57 pm
Its hard to see but theres a GM part number on the outer rim of the balancers between the two belt grooves. Its quite faint but its there....if its a GM part.
Harmonic Ballancer
Post  fliermike45 on Sun Mar 07, 2010 6:07 pm
Have looked all over but could not find any additional numbers.
Must assume that it is an aftermarket unit.
Post  944-LT1 on Sun Mar 07, 2010 6:54 pm
If its been painted, its possible its covered. But yeah it could be aftermarket. Got a pic? Heres mine from a 2009 LS. You can just make out the numbers.
Post  944-LT1 on Sun Mar 07, 2010 7:36 pm
This is an LS2 balancer stamped with NH1480. If it looks like this one, its from an LS2 vette. It could also be from an LS6 though.
Harmonic Balancer
Post  fliermike45 on Mon Mar 08, 2010 11:19 am
Thanks guys for your inputs.
I managed to contact the guy who sold me the LS1 that was removed from a C5 Vette. The HB he supplied was a replacement (don't know what happened to the original). He confirmed that the HB came from Pace Performance with a GM part number Harmonic Balancer 12553118, the pace website lists this for F-Car and GTO applications. Seems he did me a favour as I am changing over to F-Car accessories.
Thank you all again.
Post  944-LT1 on Mon Mar 08, 2010 1:36 pm
Excellent.
BTW.....just me and you here. Laughing Laughing
Correction
Post  fliermike45 on Mon Mar 08, 2010 5:46 pm
Thanks guy!
Now I have to fix the Power Steering pump problem.
