Heat sleeving for remote oil lines and coolant lines
So, is everyone running a heat shield for the oil lines that run near the headers? I am thinking that wrapping/sleeving the oil lines and maybe the heater lines would be a pretty good idea. What is recommended out there?
robstah- Posts : 352
Re: Heat sleeving for remote oil lines and coolant lines
robstah wrote:So, is everyone running a heat shield for the oil lines that run near the headers? I am thinking that wrapping/sleeving the oil lines and maybe the heater lines would be a pretty good idea. What is recommended out there?
- Can you reroute oil lines? Chances are they will pick up a bit of heat from the headers.
Here is a (catalog) link to Browne & Miller:
Browne & Miller Racing
Check section 10 of the catalog for protective sleeves. It is high quality, NASCAR, etc.
They can also custom fabricate lines with sleeves, etc. installed & can advise per your requirements.
Last edited by lbp on Thu May 26, 2011 6:31 pm; edited 3 times in total (Reason for editing : add info)
lbp- Posts : 24
I installed heat sleeves on my hoses. I bought mine from summit; the taylor brand the summit brand sleeves.
In addition to what 944-LT1 did I also added the same type of heat wrap around the sections of exhaust which came close to the oil lines....
I ended up finding something on mcmaster when I was looking for bolts. Here's a link if anyone is interested. It should be here tomorrow.
