Running the coolant lines
Hey all!
I’m almost done with my 5.3 swap and on to running the coolant lines. I was just curious what everyone has done too cobble together the coolant lines. I am also curious what people have done for running the fuel lines to the rails with the old 944 lines in place? Or ran all new lines to the rails?
Thanks in advance for any ideas!!
PS I am struggling with the clearance for the intake also ????
Bo05T- Posts : 7
Re: Running the coolant lines
I went to the parts store, went into the back, and literally spent 30min measuring and "visualizing" the coolant lines I needed. Ended-up buying (6) different pre-bent coolant lines, cut them all up to fit into the car, then threw the remaining 75% in the spare parts bin, lol.
As for the throttle body clearance, good luck! I spent weeks working and re-working and re-re-working. Ended up with a Motion Raceworks low profile mechanical throttle body, and custom-cut intake tubes, and K&N filters.
https://www.instagram.com/p/C0FGIenxQIr/?igsh=MW1sOHduN3ZlMDcxZg==
Hope that helps? ... I also have 100+ videos on my youtube.
youtube.com/powersports
MotoRider42HC- Posts : 116
I see you have a cable throttle body, so I don't know if this will be useful for you, but with my DBW throttle, I flipped it upside down to gain more clearance. I still had to clearance the hood a bit to clear the top of the intake.
For coolant lines I did Like MotoRider - got access to the back of the parts store and browsed for what I thought might work. (It kinda did, eventually...) I also ordered a T for the expansion tank line from https://jagsthatrun.com/.
majormojo- Posts : 82
I ran a direct line from expansion tank to the custom radiator. Then i ran all four engine steam ports to the steam port on the expansion tank. Lot of work to route the steam ports...
Thanks for the response! Yeah I’ve been struggling with these damn lines for a while! I was also curious how everyone ran the fuel lines to the rails, seeing as how the OE lines for the 944 are globe fittings. Do you just run all new lines with AN fittings?
Bo05T- Posts : 7
Yeah, i went the very hard route and ran a brand new pump, filter and Aeroquip PTFE stainless braided lines. But also my car was an off-road racecar. LOL. You'd be fine with just normal stainless braided lines.
» Heat sleeving for remote oil lines and coolant lines
» LS Heater / Radiator / Reservoir Plumbing
» heater valve
» heater valve
» Turbo Transaxle wanted
