New convert under way
+48
superman22x
turbobob924
RestomodCorvettes
chrenan
iamgod
944_GASM
Hotrodz of Dallas
racertomtom
sparkydog
matt889
HorizonblueDK
crowstyle
pa951
ScottM1A
Slpr948
erioshi
blown 9442
Robb Northrup
Gutterboy
bluejk09
cjbcpa
eclou
kelleysj
Insulator
skywalker01
applebit
MillsMotorsport
suboptimalfit
a951
Dan J
laptop_geek
singleslammer
52 posters
Page 10 of 31
Page 10 of 31 • 1 ... 6 ... 9, 10, 11 ... 20 ... 31
wide body
I will take a few more pics of my wide body conversion and post, keep in mind still in the shaping stage. lots of R&D to make work but coming along.
kevin924kevin- Posts : 927
LS3
Well today is the day. The heart of my build lands. I will post more pics of the car and the new motor when i return. Heading to Pheniox for a week, get the heck out of the cold.
Re: New convert under way
Yeah pics needed!!!
kelleysj- Posts : 194
motor
Well back from pheniox.i was gojng to pick up my engine today but tne darn roads are closed. I will now have to wait for the roads to open. I have been waiting to plck the darn thing up and i cant.i guess one or to more days wont kill me. Just want to see it up close and to drop in to the engine bay.keep you all posted.pics to come,have to get squared away after 9 days away.
LS3
Heading to pick up my mill finaly. Will post some picks of the unit when it gets home. It will be nice to have the final big piece of the puzzle. Just littlte things left for the drive line, then carry on with the body mods, have made some progress with that will take a few picks of that aswell.
LS3
Well she is here a thing of beuty. Question why cant we cut off the top two bolt holders for the rack and weld a plate in the middle of the rac and do a triangle back to the face of the cross member move the left side bolt boss over a couple of inches. This is what i think i am going to do. This will aloow me to run the stock oil pan with out any issues. Let me know what uthink.Thanks
LS3
[You must be registered and logged in to see this image.] Well here it is,it sustained some mild damage in shipping but that is being addressed. Next is to set it in place and see how it fits. 2009 LS3 rotating assem has 20 thousand mile on it other wise she is new.
The stock ls2/ls3 oil pan isn't so great. Lots of Camaros and Vettes blow up at the track. If you plan on sticky tires and long corners, an aftermarket baffled pan is a good idea anyway. And it leaves the steering rack attachment as original.
That is a thing of beauty.
LS3
Thank you, Rich. Which pan do u run, is it one from Eric?
Yep, TPC. I think he starts with a Moroso pan and modifies it. The fit wasn't very good but I understand he's made some updates recently.
oil pan
Rich, does Erics pan come baffled, or did u have to add?
Pretty sure his are baffled.
My new pans now have a baffle tray in them as well as the square in the bottom with baffle doors around the pick up tube end. I think these are the best of the best, just my 2 cents
And these are not Moroso pans......
LS3
ADMIN,the pan looks good. Iwant to set my motor in place and access my situation.
Yeah, looks great. I stand corrected...
Part of me wants to build another 948 as a street car. Just to use this new oil pan with the spin on filter and those great looking shorty manifolds.
Admin wrote:have a baffle tray in them as well as the square in the bottom with baffle doors around the pick up tube end
Too much oil going to the top end is a known issue with these engines.
Many of the corvette racers use .040 restrictor pushrods and/or modify the lifter retainers to ensure enough oil stays available at the pick up tube end.
A couple of cheap and easy solutions before stepping up to an Accusump or Dry Sump kit.
944convert- Posts : 253
LS3
Well ,tonight i install the engine and see how it fits. I will post some picks later.Should look good with the front end on my car. Curious to see hood clearance, and pan, being that my factory cross member is steel.
LS3
[img][You must be registered and logged in to see this link.] CAN SEE THE NICE CLEARANCE [You must be registered and logged in to see this image.]70.servim[You must be registered and logged in to see this image.]g.com/[You must be registered and logged in to see this image.]u/f70/16/17/65/65/hpim1411.jpg[/img][/url][img][You must be registered and logged in to see this link.]/16/17/65/65/hpim1415.jpg[/img][/url][img][You must be registered and logged in to see this link.]0.servimg.com/u/f70/16/17/65/65/hpim1417.jpg[/img][/url][url=https://servimg.com/view/16176565/113][You must be registered and logged in to see this image.][/url
These picks show the hood clearance, with it closed i can put my hand on top of the intake and there is still abit of room.
I cant get over this hybrid such a cool idea and i cant wait to see the finished product. I check this thread daily just for new pics. Great job Kevin.
Well it fits pretty darn nice. I need to oblong my mount holes in the cross member and make the shims needed. I will get more pics tonight camera packed it in last night. I will show how my mounts sit on the cross member, my angles are a bit different from the alum one but expected this. You can see lots of hood clearance. It closes with no issue at this point.
More pics
[][img]http[url=https://servimg.com/view/16176565/122][You must be registered and logged in to see this image.][/ur[url=https://servimg.com/view/16176565/123][You must be registered and logged in to see this image.]l]://i70.servimg.com/u/f70/16/17/65/65/hpim1429.jpg[/i[You must be registered and logged in to see this image.]mg][/url]
pics
Just more pics. I have more to down load.
» Do or Don't convert with L83 motor?
» Convert 1986 to 1987+ Offset
» Convert 944 LT1 Swap to LS Swap
Page 10 of 31
Today at 8:32 am by Rob44
Today at 8:28 am by Rob44
