New convert under way  - Page 31 EmptyYesterday at 11:51 am by geegeesbits@gmail.com
New convert under way  - Page 31 EmptyMon Jan 27, 2020 2:27 pm by Porsche951toLS3
New convert under way  - Page 31 EmptySun Jan 26, 2020 4:51 pm by j7wolfe
New convert under way  - Page 31 EmptySat Jan 25, 2020 6:42 pm by kevin924kevin
» Pedal Assembly - Which one?
New convert under way  - Page 31 EmptyTue Jan 21, 2020 5:27 pm by Hotrodz of Dallas
New convert under way  - Page 31 EmptySat Jan 18, 2020 7:15 am by Rothaus
New convert under way  - Page 31 EmptyThu Jan 16, 2020 6:51 am by 87944turbo
» 82 924 with AUX Audi V8.
New convert under way  - Page 31 EmptyThu Jan 16, 2020 2:11 am by Golten1986
New convert under way  - Page 31 EmptyTue Jan 14, 2020 2:48 pm by Gumby
New convert under way  - Page 31 EmptyTue Jan 14, 2020 6:43 am by 87944turbo
January 2020
6789101112
13141516171819
20212223242526
2728293031
Page 31 of 31 Previous  1 ... 17 ... 29, 30, 31
New convert under way  - Page 31 Empty Re: New convert under way
Post  Hotrodz of Dallas on Sat Jan 11, 2020 2:38 pm
I thought that might be Hanks work. I've used his stuff a few times. Always fits right.
Hotrodz of Dallas
Hotrodz of Dallas
Post  kevin924kevin on Mon Jan 20, 2020 10:01 am
So how are the kook headers working? Anyone put them on after having other manifolds? If so did you notice an increase in power/torque? I remember reading that they added a good 50 to 70 HP. I have the manifolds form TPC and i am concidering changing to the long tube units.
Post  Hotrodz of Dallas on Mon Jan 20, 2020 10:41 am
I have used the kooks headers on a few of these now. They definitely make more power than the manifolds. One car that we dyno tuned with a stock LS1 made 310hp at the wheels. Another with the kooks made 345hp.
Hotrodz of Dallas
Hotrodz of Dallas
Post  kevin924kevin on Mon Jan 20, 2020 11:35 am
Thank you. So it looks like there is a benefit to these headers. Now what about adding a 102 throttle body. I have the Fast 102 intake. Anyone have this set up? Any difference?
Post  Hotrodz of Dallas on Mon Jan 20, 2020 4:39 pm
You are using a crate LS3? If so, the Fast intake and 102 throttle body likely won't give you much improvement over the stock LS3 stuff. You would gain some hp but lose some low end torque. Which isn't necessarily a bad thing, as the car is light and will be stupid fast anyway.
Hotrodz of Dallas
Hotrodz of Dallas
Post  kevin924kevin on Mon Jan 20, 2020 5:10 pm
I have the 480 hp LS3. Started as the 430 then did the gm hot cam springs etc. When I did the cam I did a lot of research. All reviews started with 430 hp and headers. All did a proper tune to stock 430. On average all tuned 430 to 490 to 493. Then cam change. I figure with the tubes and a good tune I should be around the 530 hp plus or minus. Re views were by hot rod mag and car and track.
Post  kevin924kevin on Mon Jan 20, 2020 5:31 pm
Cam 1: Stock LS3
Lift: .551 in/ .525 ex
Duration @ .050: 204 in/211 ex
LSA: 117
Idle vacuum: 20.3 in-Hg
PV Intake: .150+
PV Ex: .150+
Cranking Compression: 205 psi
Peak Power: 496 hp @ 5,800 rpm
Peak Torque: 491 lb-ft @ 4,700 rpm
Ave HP (3,000-6,500): 408.9 hp
Ave TQ (3,000-6,500): 452.4 lb-ft
Tq @ 4,000 RPM: 461 lb-ft
Dyno Graph Cam Test Stock Ls311/14
The stock camshaft offered a perfect idle, good power, and plenty of P-V. Now it was time to step things up with the other cams.
Post  kevin924kevin on Mon Jan 20, 2020 5:32 pm
this is a dyno tune by super chev for cams tests. My cam is the GM hot 525 intake/ex , 219 in / 228 out LSA 112
Post  Hotrodz of Dallas on Tue Jan 21, 2020 5:33 pm
I'm building an LS2 for my Saab 97x Aero. My goal is 500hp flywheel. After a lot of research and talking to my tuners, I am going to use the LS9 cam.
Duration @ .050" Lift( Deg): Intake: 211 / Exhaust: 230
Maximum Lift (in) W/ 1.7 Rocker: Intake: .562 / Exhaust: .562
Lobe Centerline ( deg): 122.5
My tuner said he has installed this cam in several LS motors and it produces a lot of HP and TQ. Even though it's designed for the supercharged engines, it works amazingly well. It's my daily driver, so I didn't want a lopey idle.
Hotrodz of Dallas
Hotrodz of Dallas
Post  kevin924kevin on Sat Jan 25, 2020 6:38 pm
Post  kevin924kevin on Sat Jan 25, 2020 6:41 pm
Post  kevin924kevin on Sat Jan 25, 2020 6:42 pm
