New convert under way
+48
superman22x
turbobob924
RestomodCorvettes
chrenan
iamgod
944_GASM
Hotrodz of Dallas
racertomtom
sparkydog
matt889
HorizonblueDK
crowstyle
pa951
ScottM1A
Slpr948
erioshi
blown 9442
Robb Northrup
Gutterboy
bluejk09
cjbcpa
eclou
kelleysj
Insulator
skywalker01
applebit
MillsMotorsport
suboptimalfit
a951
Dan J
laptop_geek
singleslammer
52 posters
Page 9 of 31
Page 9 of 31 • 1 ... 6 ... 8, 9, 10 ... 20 ... 31
Axles
Rob, once everything is sitting permanent, i would like a set of the chrome moly ones you make. I have the CV's from EMPI etc. I just need to be able to get the final length for them. Bin busy with family stuff, but getting back at it.
kevin924kevin- Posts : 927
Re: New convert under way
I did some work with the Piranha Brothers and they stabbed the C5 trans in a 928 and it all clears except the rear weissach (SIC) member needs to be modded. Got me thinking about my next build.
trans
Rob, what are you thinking, maybe a 928 conversion in the future or the 944 with the complete vette drive line.
The 928 tunnel is bigger, therefore the Vette TT fits and the rear area needs a small hammer job and the axles are 930 cv's so that's a no brainer. The Shifter Lines up perfectly with the factory shifter location. The 928 has a double wishbone susp. too.
BTW, I see you got the rear tunnel clearanced LOL
Doug and Dinsdale made history with this set-up.....Factory 928 Dual Clutch system retained too...
trans
Rob, i see the fac porsche engine attached to the vette tt. very interesting.
cage
Well took the plunge and ordered the rear cage section. Time to get this project back on track. I will post some pics once the cage etc. is finalized. My only issue at this point is the rear sway bar. I have started looking at some custom made units that will use the factory mounts.more to come.
cage
Just an update the last piece of the puzzle has finally been shipped. The new cage is to arrive on the 7th or 8th. Total weight for the cage unit is 72 pounds. This will finally allow some serious progress.
c5
Well progress has been slow. Work has away of doing that. But finally i am heading to the border today to pick up the cage unit. Winter is coming so my time should be able to get back to work.I will post some photos of the unit when i have it sitting in place.
cage
Well made it to the US and picked up the main section of the cage. I have it temped in place. Another fine product by Hanksville hot rod. Once i have it completely tacked in place, i will post some pics.This will finally allow me to make some progress in the right direction.
cage
Well a bi[You must be registered and logged in to see this image.]t of work started. Here are a few pics of th[img][You must be registered and logged in to see this link.]rvim[You must be registered and logged in to see this image.]g.com/u/f47/16/17/[You must be registered and logged in to see this image.]65/65/hpim0911.jpg[/img][/url]e test fit of the cage.[[img][You must be registered and logged in to see this link.]5/65/hpim0915.jpg[/img][/url][You must be registered and logged in to see this image.]
cage
Well as you can see some progress. I need to make a few adjustments, but all and all fits really clean. You can see where it ties in to the cross member for max support. i can now start the final fitment, and let the welding begin. I will still be able to run the factory interior, where i want. This should offer some good support and side impact strength. will keep you all posted.
engine
Well i finally broke down and purchased the heart of my build. I found a 2010 LS3 with 1100 km on it and the price was good.i beleave i have to use the f body alt and brackets is this correct. I have no power steering but i would like A/C. any info would be greatly appreciated.
You will need the Fbody alternator bracket and ac bracket as well as harmonic balancer , also the water pump. What did the LS3 come out of? you might check the dimensions on the balancer and water pump. If it came from a new camaro you may be able to use them as well as the other brackets.
engine
Admin,The motor came out of a 2010 corvette C6. I will be contacting you after x-mas, will need oil pan and engine mounts. Do u have stock by chance. I read here u have a new pan design with the filter in its facory location is this right. Merry Christmas. Thank you, Kevin.
I will have three pans coming in just after Xmas, Motor mounts and upright are in stock. I will also have the brackets in stock as well.
engine
Admin, thank you , i will contact right after X-mas.
C6
Just an update my LS3 will be shipped to me on the 10th of Jan, cant wait.
motor is a scam
Well, kinda crapy that my motor turned out to be a scam. I am now in the process with Paypal to get my cash back, i have to waite 8 more days for it to be resolved. On the bright side i found one with under 1600 km out of a brand new camaro. MTI stage 3 cam,fancy double springs etc. I would need to get a manafold and a few things for this one but not the end of the world. All i can say is thankfuly i paid with Paypal and i am protected. Watch out for deer_us on ebay, just a scam artist. He also had an LS7 he was pedling.
engines
Question, would an LS7 work in these cars. after my LS3 went south i have a good lead on an LS7 thoughts?
motor
Well its a done deal finally. Just purchased an LS3.This one is not a scam. Its from corvettes of Manchester, in New york. It has 20K on the rotating assemblies, and everything else is new from heads to pan. He also has a guy that does free standing wiring harness, cant wait to couple this to my Z06 6 speed trans and set in place on the mounts from Eric ( high quality product by the way ). will take some picks when they are mated.getting down to the skinny of the parts i need, just a few more items to go. Will have to total up the cost of this build to c where i am at one of these days. My guess right now with the body parts included about 15k ( dont tell my wife). has anyone dynoed one with the lS3?
motor
YA, its on its way to me, cant waite.
This is a really sweet build can't wait till you get it done. Im sure you will post all the details.
Last edited by kelleysj on Wed Jan 30, 2013 12:44 pm; edited 1 time in total (Reason for editing : misspell)
kelleysj- Posts : 194
C5 Drive line
Thank you for the kind words. I cant waite, but its a slow build for me not alot of time right now, work is busy, but that will change soon and i can really dedicate the time . Should be a real treat to drive.
I like the idea of the hatch and the way it looks with this body style! Absolutely thought outside the box on this one.
» Do or Don't convert with L83 motor?
» Convert 1986 to 1987+ Offset
» Convert 944 LT1 Swap to LS Swap
Page 9 of 31
Yesterday at 8:32 am by Rob44
