Anyone used a truck motor or FWD v8?
I'm curious to see if anyone has used the LS4 or the Truck motor for a conversion? It seems that these motors are much cheaper than the LS1. I'm also having a hard time finding a motor. Does anyone know where exactly to look for these motors at?
billymild- Posts : 24
LM7
I installed the 5.3l LM7 TRUCK motor in mine with the LS1 corvette intake. 43K mile motor and accessories for $700 IIRC. LS1 intake $75. The 5.3l injectors fit right in the LS1 manifold. I am hunting for a 5.3l wiring harness as we speak because the yard where I got the motor has harnesses with various connectors missing. I am using the Fidanza LS1 Flywheel and Camaro Pressure plate and a CP4018 Clutch disk $40 from Autozone.
And I have not used for the anything from Renegades, keeping the swap under $3500.
Oh yes, and member Johnny Johnny has installed the all alloy 5.3l engine as well
PORH
PORH
Re: Anyone used a truck motor or FWD v8?
what connectors are you missing? Ive run into a few websites that have the oem housings (tabs separate)... probably cheaper to grab some from the scrap yard though.
Tetzuoe- Posts : 178
LS4 Issues
The LS4's (FWD) starter is on the transmission. If you can solve for that challenge, it might be a good choice. The next hurdle would be where the water lines enter/exit form the motor and if they interfere with the 944 body etc.
968gene- Posts : 259
Growing
More and more folks are catching on. 2 more people on the hunt for 944's with blown motors....
I got my 5.3L off a guy from here a few months back.....
