DBW truck throttle body
Ok, I searched and couldn't find the answer to this so I am asking this question. I am at the point of gathering up the parts that I don't have for the engine. Will a DBW throttle body off of a 5.3 or 6.0 work with the LS1 Corvette intake, or should I look for a f body or y body one? I have the opportunity to trade some of the GM parts that I don't need with some things I do need.
jsautomotive- Posts : 14
Re: DBW truck throttle body
I don't think it will. The truck body is an 78mm DBW I am not sure on the LS1 size, on my LS2 intake with the DBW it is a 90mm I think.
99sierra4x4- Posts : 121
I doubt the TB diameter matters...but the ECU you are using e.g. using an E38 probably requires a DBW pedal from any model that ALSO uses an E38 ECU
In Google, type in:
DBW -DBC site:http://ls1tech.com/forums/conversions-hybrids
This will seach and bring up ls1tech.com forums posts that discuss DBW issue minus DBC issues and let us know what you find.
In Google, type in:
944convert- Posts : 253
Here's a link that has some good info on LSx interchangeability.
I have a truck 6.0L DBW TB ('08 Silverado HD) on my LS3 intake. No problems with fitment, but I haven't started the engine yet, so perhaps there are gremlins lurking. I picked up a compatible pedal from a local wrecker for $6.
majormojo- Posts : 82
My bad, it is a cable throttle body not dbw.
