Truck engine
Truck engine
Hey guys I'm looking at sourcing my engine and I have found an iron block LS2 truck engine well with in my budget. I know that I need the LS intake manifold and that the heads are slightly different. I'm curious as to how much heavier is the iron block than the aluminum? Can I use LS1/3/6/7 heads with this engine? And is there any other parts that are necessary for it to work properly? Thanks
jimbo93- Posts : 14
Re: Truck engine
above is a very nice writeup from an experienced swapper on why he only uses the truck motors. The weight difference according to him is 65#
eclou- Posts : 102
Re: Truck engine
I was curious to this too. Seems like the 6.0 lq4 engines are basically the same price as the 5.3's...
HandofTron- Posts : 22
