Rear battery mount
+4
8 posters
Rear battery mount
Does anyone have pictures of their battery mounted in the rear of their car? Will it fit completely down in the well area?
Re: Rear battery mount
Admin wrote:Does anyone have pictures of their battery mounted in the rear of their car? Will it fit completely down in the well area?
No pics, but I have mine in the spare tire well in the middle of the car. It fits all the way down in the well. I have to use 0 gauge wire since when the motor is hot (And everything in the motor is tight) it bog's.
Dawgz83948- Posts : 603
Cool...
Will the carpet cover it?
What'cha got in mind fo' dat?
gt1scca- Posts : 795
The carpet covers it,but it is just a bit high. I plan to make a small cover for it and trim the factory carpet and cover the cover There will be a couple of inches difference between the car floor and the top of the battery.
As far as weight , I don't know. not a consideration on this it was a mater of needed the battery box space.
38.8 lbs
http://www.1st-optima-batteries.com/?gclid=CIjRn4HAup4CFRLyDAodLVDDeg#redspecs
34/78 model
34/78 model
Beautiful! I like it.
ghostcloak- Posts : 83
Skywalker fit 2 batteries in the spare tire mount location. We don't need no stink'n spares!
Mike
Mike
I also mounted my battery in that passenger side rear well. I bought a smaller lighter battery for mine though and instead of a metal bracket like the one above (looks a little heavy) I made a wooden one with a thin piece of plywood with angle cut 2 by 4 to make it sit nicely. Then I use one of those old school black rubber bungie cords to hold the battery against the side of the well. My carpet sits down just about pefect on top of the battery.
I ran 0 gauge wire as well if I recall correctly. I haven't had any starting issues or anything even in cold weather. When I say cold I only mean down into the teens.
matthewb- Posts : 53
» 944 S2 - LS3 & T56 Conversion
» $175 Brake Adapters to mount FC RX-7 brakes on rear
» Techno Duck's LS1 conversion
