Oil lines - clearance with header
Hi,
Looking for advice regarding routing of oil lines to/from the remote filter.
Using the Moroso pan, ceramic headers and remote oil filter kit as purchased from 944v8.com.
Filter is mounted drivers side front.
Lines routed over the crossmember & steering rack
Even with insulation wrap, the lines are very close to the header. Anyone have a good solution to suggest for re-routing the lines? I was thinking of trying to find a longer 90deg for the rear-most line in order to stack them and run them along the pan.
Thank you,
Dan.
Thank you,
Dan.
Dan J- Posts : 117
Re: Oil lines - clearance with header
Yeah you're going to have to fix that. That is dangerously too close. You should have a hydro shop make some hard tube extensions to bring the 90's down so the polymer lines are away from the header.....and wrap everything.
The answer is in your question. Longer AN fitting for the rear.
You should Dremel your collector a bit.
Just what I thought - much appreciated advice gentlemen. I figured that would be an issue common to anyone using that pan/line combination.
I have a nice little list of stuff to pick up from the hydraulics shop. Thankfully there's one here in Portland and the counter guys are cool about helping me figure out how to make things work.
I'll post a photo once that's sorted out.
Dan.
Dan.
Dan J- Posts : 117
Definitely post pics of your find. I have the Modded Hooker 2312 headers and they clear the oil lines by a mile, but I wish I had -10AN long tubes to the 90 degree bends to make installing them alot easier. I Had to cut a brand new 1" open end wrench down to a stubby to get in there
Resolution
Hi,
Found a reasonable solution for those with the remote oil filter setup, Moroso pan and S&P header combination.
The oil filter relocation kit from 944v8.com comes with 2x 90deg AN10 fittings for connecting to the Moroso pan. I replaced the rearmost 90deg AN10 fitting with a 45deg fitting.
This makes it possible to keep the oil lines tight up against the oil pan and about 2" min from the collector. Seems like a reasonable solution based on the limited routing options available.
Will post a picture of this later today.
Dan.
Dan.
Dan J- Posts : 117
Portland? East cost or west coast? (sorry for off-topic)
adam7e- Posts : 63
» dumb question time -master cylinder and hard lines - or stainless lines?
» What header is everyone using?
» My Header Solution
