Transmission reinforcement plates, We got'em
+6
968gene
modenas
10 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Transmission reinforcement plates, We got'em ,come and get 'em while they last.
PM me for cost and shipping.
Re: Transmission reinforcement plates, We got'em
How thick, what material?
stupid question:
gasket or just glue when installing them?
modenas- Posts : 285
What happened to all you guy's that wanted a plate? It seems that everyone wants parts , but when they are available, It's like a ghost town.........................
Maybe this is the reason Greg has such a bad attitude about this..................
Thank you to the few people that have purchased parts, From here on out, if you want a new part made or designed, be ready to put up your money. It take time , money and a lot of effort to get things, even simple ones, done. You guy's need to think about this when your asking for thing to be made.
Didn't see this until now, it will definitely be on 'the list' at some point. Wish i had see them when i was doing the 5th gear swap, i would have definitely picked it up (now i just don't want to pull the trans back out...).
I didnt see this until this morning. Definetly interested, I sent you a pm
Parts
Have you tried selling these on the GT40 site? They are always looking for ways to allow the Audi boxes to handle more torque.
968gene- Posts : 259
I got one! Thanks for all the effort Eric!
As is will they fit if a fifth gear swap is part of the plan?
Guest- Guest
They should fit without a problem, I had them cut with a little larger gear hole than the drawings originally showed. The original dimension would not clear the gears at all.
are you holding one for me? I get my money wensday.
sweet thanks
PLease pm with amount shipped to 27603,
thanks, you'll be seeing my name pop up more now that I got my project car!
-Bryan
-Bryan
B.Rudy- Posts : 40
Got mine also
Got one thanks, perhaps if Sloan gets his act together I will have two!
These are great plates. After i had my tail shaft housing milled to match the plate thickness, it bolted up with no problems at all. And the outside edges stay close to the actual shape of the trans axle casing so it doesnt look bulky. I put a little bit of black rustouleum paint on the outside surface of the fresh steel that was sticking out side of the case and now it looks great.
Awesome! How much did you have to pay to get the end case milled?
40.00 is what I paid. At first when talking to him he said 80.00 but it didnt take him but an hour so he dropped the price.
I'm looking for someone to do mine this week, I bet because of where i live it will be painful. Did you replace the ball bearing?
No, it didnt seem to be in bad shape at all. I figure with the oil in the case it would keep good.
Dropped my tail section off for machining today, will be less than 50 bucks!
Take alittle caution when installing the plate. I had to take it back off due to hitting the shift rods wrong and jamming the trans into two gears at once causing a shift lock. I decided to take a picture of the plate installed with out the tail housing to show it is nice. Double check all of the shift rod movement and the shafts clear the holes with minimum clearance and do not bind at all.
Good work Eric.
87-944S did you drop off the plate too? It is important to get the housing milled to the plates measurement as close as they can.
Good work Eric.
Page 1 of 2 • 1, 2
Page 1 of 2
Yesterday at 3:06 pm by Rob44
