Today at 3:12 pm by kevin924kevin
» LS6 Batwing Oil Pan
Today at 2:13 pm by Hotrodz of Dallas
» LS3 Exhaust
» JP's LS1 Conversion
» Steering shaft short
» ecotec swap
» 86` 944 turbo project
January 2018
Transmission reinforcement plates, We got'em
Page 1 of 2 1, 2  Next
Post  Admin on Wed Aug 18, 2010 3:12 pm
Transmission reinforcement plates, We got'em ,come and get 'em while they last.
PM me for cost and shipping.
Re: Transmission reinforcement plates, We got'em
Post  xschop on Wed Aug 18, 2010 3:17 pm
How thick, what material?
Post  Admin on Wed Aug 18, 2010 3:21 pm
1/4" steel
Post  modenas on Wed Aug 18, 2010 3:49 pm
stupid question:
gasket or just glue when installing them?
modenas
Post  Admin on Fri Aug 20, 2010 9:34 am
What happened to all you guy's that wanted a plate? It seems that everyone wants parts , but when they are available, It's like a ghost town......................... Sleep Sleep Sleep
Maybe this is the reason Greg has such a bad attitude about this..................
Thank you to the few people that have purchased parts, From here on out, if you want a new part made or designed, be ready to put up your money. It take time , money and a lot of effort to get things, even simple ones, done. You guy's need to think about this when your asking for thing to be made. Mad
Post  Porch on Fri Aug 20, 2010 12:05 pm
Didn't see this until now, it will definitely be on 'the list' at some point. Wish i had see them when i was doing the 5th gear swap, i would have definitely picked it up (now i just don't want to pull the trans back out...).
Post  cfgioja on Fri Aug 20, 2010 12:11 pm
I didnt see this until this morning. Definetly interested, I sent you a pm
Post  Admin on Fri Aug 20, 2010 1:24 pm
PM sent
Parts
Post  968gene on Fri Aug 20, 2010 7:43 pm
Have you tried selling these on the GT40 site? They are always looking for ways to allow the Audi boxes to handle more torque.
968gene
Post  docwyte on Sat Aug 21, 2010 5:19 pm
I got one! Thanks for all the effort Eric!
Post  Guest on Sun Aug 22, 2010 6:12 am
As is will they fit if a fifth gear swap is part of the plan?
Guest
Guest
Post  Admin on Sun Aug 22, 2010 10:01 am
They should fit without a problem, I had them cut with a little larger gear hole than the drawings originally showed. The original dimension would not clear the gears at all.
Post  Admin on Sun Aug 22, 2010 5:51 pm
ONLY 4 LEFT!
Post  cfgioja on Sun Aug 22, 2010 5:53 pm
are you holding one for me? I get my money wensday.
Post  Admin on Sun Aug 22, 2010 6:05 pm
Yes,
Post  cfgioja on Sun Aug 22, 2010 6:07 pm
sweet thanks
Post  B.Rudy on Fri Aug 27, 2010 10:01 am
PLease pm with amount shipped to 27603,
thanks, you'll be seeing my name pop up more now that I got my project car!
-Bryan
B.Rudy
Got mine also
Post  fliermike45 on Fri Aug 27, 2010 2:31 pm
Got one thanks, perhaps if Sloan gets his act together I will have two!
Post  cfgioja on Sat Sep 11, 2010 5:20 pm
These are great plates. After i had my tail shaft housing milled to match the plate thickness, it bolted up with no problems at all. And the outside edges stay close to the actual shape of the trans axle casing so it doesnt look bulky. I put a little bit of black rustouleum paint on the outside surface of the fresh steel that was sticking out side of the case and now it looks great.
Post  Porch on Sun Sep 12, 2010 3:19 pm
Awesome! How much did you have to pay to get the end case milled?
Post  cfgioja on Sun Sep 12, 2010 4:11 pm
40.00 is what I paid. At first when talking to him he said 80.00 but it didnt take him but an hour so he dropped the price.
Post  87-944S on Sun Sep 12, 2010 8:47 pm
I'm looking for someone to do mine this week, I bet because of where i live it will be painful. Did you replace the ball bearing?
Post  cfgioja on Sun Sep 12, 2010 9:29 pm
No, it didnt seem to be in bad shape at all. I figure with the oil in the case it would keep good.
Post  87-944S on Mon Sep 13, 2010 2:38 pm
Dropped my tail section off for machining today, will be less than 50 bucks! Very Happy
Post  cfgioja on Mon Sep 13, 2010 4:50 pm
Take alittle caution when installing the plate. I had to take it back off due to hitting the shift rods wrong and jamming the trans into two gears at once causing a shift lock. I decided to take a picture of the plate installed with out the tail housing to show it is nice. Double check all of the shift rod movement and the shafts clear the holes with minimum clearance and do not bind at all.
Good work Eric.
87-944S did you drop off the plate too? It is important to get the housing milled to the plates measurement as close as they can.
