master cylinder question.
+4
tntocco
8 posters
so ive seen a lot of talk about electric brakes and hydraboost stuff. when performing a swap do the stock components not fit anymore? or is this just a personal decision to better the braking on the 944's.
tntocco- Posts : 9
Re: master cylinder question.
All this is covered multiple times on the site, have you done a search?
You can't run the factory brake booster with the LS1, the motor is too wide. So you need to change your brake setup to one of the many choices detailed on this site.
if you enter into the search box:
electric brakes hydraboost
you will get the results of this URL:
https://944hybrids.forumotion.com/search?search_keywords=electric+brakes+hydraboost
which will have a wealth of info.
and post a reply on the thread(s) you have questions about ;-)
944convert- Posts : 253
yep did that and read it, just wasnt sure if it was something that HAD to be done or if it was something that you guys were doing for better brakeing. thanks for the info. also, i search things nonstop, but its nice to have verification. i am sure that at some point on this journey you all telling me to search nonstop have asked questions that have been covered before. i used to build mustangs and have seen the question about the best exhaust asked by new people hundreds of times. they are just trying to learn or verify info they got or heard from so and so. plese have patients, i know how to search and just want to have everything before i tear my running posrche apart to do this swap. thank you again for your patients and info. hopefully next time i speak ill have my ls1 in the car. it came out of my buddies old vette ( made 493 at the wheels in the vette). should be a monster in the porsche hehehehehe.
tntocco- Posts : 9
Holy cow! That'll be wild. One challenge you'll have it headers. I have TPC's long tubes, 3" to a y-pipe and single 3" out the back. Did that Vette have anything special for exhaust?
Post! Please keep us posted with pictures of your progress in a build thread. And feel free to ask questions. They'll get smarter and smarter as you go along...
ok, im totally lost on this, so the LS is in the car and obviously the mc wont fit where it was supposed to go...... so where does it go??? are people fabricating linkages and fancy mounting??? is there something that is fairly simple to do/use??? this is not a race track car it is a street car, but i would still like it to stop decently. ive looked through the link listed above and didnt really find what people with the swap were really doing. also im a little slow on the whole breaking thing is the mc the same thing as the break booster???
tntocco- Posts : 9
You have a few options. One is ditching the stock vacuum booster (the round black saucer shaped deal) and attaching the master cylinder (silver cylinder shaped deal with the fluid reservoir on it) right to the firewall. This requires an adapter plate and may involve moving the attachment point on the pedal arm. This may cause firewall flex and cracking.
Another option is replacing the vacuum booster with a hydraulic booster. Called hydraboost or hydroboost this takes pressure from the power steering system. BMW, Ford and Chevy systems have been made to work. This is probably the most complicated solution.
What I did was a fully manual pedal box on the driver's floor. This is most expensive and also only works if you're 5'9" or under.
Another option I looked into was mounting the vacuum booster somewhere else and using a lever arm from the brake pedal to actuate it. I haven't seen anyone active on this forum make it work.
has anyone tried welding a thicker section of plate to the fire wall to help with the flexing of it? there must be a way to reinforce the area. ill come up with something at work tomorrow on my lunch break. (the benefits of working in a fab shop lol).
tntocco- Posts : 9
Lotsa good info here: https://944hybrids.forumotion.com/search?mode=searchbox&search_keywords=firewall+reinforce&show_results=topicstntocco wrote:has anyone tried welding a thicker section of plate to the fire wall to help with the flexing of it?
acorad- Posts : 697
Reinforcement
Here is my firewall reinforcement plate, 1/8" stainless steel bolted and bonded to the firewall.
That thing turned out really good. Did you fab it up yourself or was it from a vendor? I'm in the process of gathering the parts for my conversion.fliermike45 wrote:Here is my firewall reinforcement plate, 1/8" stainless steel bolted and bonded to the firewall.
GregV- Posts : 6
Plate
I assume you mean fabricate? No I didn't, I purchased it from sloan who was a vendor until he started keeping peoples money and not sending parts. I was lucky on this item.
The Beatles were the Fab Four. LOL
You will need to add a brace to the firewall plate to keep it from flexing if you're running a non-boosted system.
