Ford 5.0 conversion ???
+17
bcjohnson
tntocco
shokwave30
haroldk
v2rocket
garyw
suboptimalfit
stu wright
matthewb
dp951
21 posters
Page 1 of 4
Page 1 of 4 • 1, 2, 3, 4
Hello.
new to the board I'm interested in the ford 5.0 swap .. can any one put me in the right direction ?
dp951- Posts : 5
Re: Ford 5.0 conversion ???
I think it would be pretty tough, honestly. Don't let that discourage you though!
The main reason i say that is because the 5.0 intake is very tall, and the distributor would also have hood clearance issues. If you have a 5.0 and a 944 lying around i think it could be fun, otherwise if you're just on a budget you should check out the 5.3 or LT1 conversions.
5.0 install
Hello l
I ve built many 951 s and 968's I do own a chevy , but I would like to do this swap I was wondering if any one on here has preformed the swap to point me in the direction on the initial install. Ive always like the ford small block.
MY builds [You must be registered and logged in to see this link.]
dp951- Posts : 5
Depends which 5.0?
A: [You must be registered and logged in to see this image.]
B: [You must be registered and logged in to see this image.]
The new 5.0 should work, doing the old hand measurments but need to see real specs. Old 5.0 not sure, seems pretty tall but the 4.7 has been done so anything is possible.
Dawgz83948- Posts : 603
Matthewb on the old board did a 4.6DOHC motor conversion.
I am here on this board as well. Just haven't had a lot of time to be online.
matthewb- Posts : 53
Well honestly, the LS motors are just an updated Ford 5.0. Might as well get the latest and greatest, right?
I worked on the 5.0L's for years. They're pretty good motors considering they were designed in the early 60's. Good luck getting them to seal with synthetic oil though...
an ls motor is definetly an update .but a stock 5.0 is no comparison to a stock ls motor which is a totaly different design from a different manufacturer.makes more power and tourqe than a stock 5.0.5.0 is a good motor to use if you have everything to bolt the motor up or someone to fab up an adapter if dont have access or the tooling to do so .xshop can probaly help you on that one or texas perf concepts.me personly would rather use the gm ls or sbc being that there is more parts out there already designed to do the conversion.and i like the power 4 dollar that you can get from a chevy.
stu wright- Posts : 312
matthewb- tell the gang about how you used christimas tree lights and adult beverages to get that thing fired the first time... Made me proud to be a Ford guy!
suboptimalfit- Posts : 61
5.3 all the way. I knew someone had dyno numbers somewhere with the 4.8 pistons installed in the 5.3..
There were 2 guys that swapped Ford v8's on the old board. One was a 5.0 the other was a modular. Both swaps had good pictures as well.
v8carreragts- Posts : 332
Has anyone got any pictures of the 5.0 swap. I have the same idea a spare 5.0 and a 944 and a smallish budget.
Thanks gary
Thanks gary
garyw- Posts : 6
i would like to see any more information anyone has regarding the 5.0 swap as i cant go to the local parts yards and NOT trip over at least 30 injected 5.0 motors. whereas chevys only run to about the end of the SBC.
v2rocket- Posts : 121
Gary, if you have a small budget, I would recommend the Chevy swap. You'll spend a ton of money and time just getting the 5.0 in place. No one make an adapter kit or headers or anything else for that matter that I know of. I won't be making them. Unless you want to send me lots of money!
Heres the only one I know of...its a 4.6L DOHC.
This is matthewB's car. He's a member here.
You will have to find a bellhousing that is between 5 and 5.75" depth that will take a clutch set-up. The Manual BH's are too deep....
Thanks 944 LT1 for the pictures that looks like a nice swap.
And thanks xschop for the bell housing dimension that saves me a job.
Gsry
Gsry
garyw- Posts : 6
I'm going to be swapping a 5.0 into my 944. I'm hoping to have it in by Spring, but we'll have to see how things work out. For reference, the deck height on the Windsor is shorter than the LS engines and the Windsor is more compact than the Mod motor. I'll make sure to take pictures along the way.
haroldk- Posts : 140
We suspended the V8 in the engine bay today. We need to get a bellhousing before we can go too much farther, but we're on the prowl. We know which one we're looking for, we just need to find one.
302
Hi There which Bellhousing are you looking at, I looked at a 302/C4 it has some good features.
What did the oil pan fir look like/
Any pictures .
Thanks gary
Any pictures .
Thanks gary
garyw- Posts : 6
garyw wrote:Hi There which Bellhousing are you looking at, I looked at a 302/C4 it has some good features.
Any pictures .
I'm looking for a 302/C4 157t bell. Once we get one of those and a rough adapter plate, we're going to start on the mounts and clearancing. As of now, we don't know how much we can notch the oil pan. Ideally, I'd like to get this thing in without dropping the cross-member, but without the bell, it's too early to say.
Since the engine was just hanging in there with no good reference points, I figured I would refrain from taking any pictures. I will say that it looks like there's enough room on the right side of the engine to fit a turbo.
The firewall will need massaging on the left side of the bay because the Ford blocks have their cylinders offset the opposite of how Chevy does it.
I bought one off of ebay shipped for $50.00 so they are out there.
If your engine is out what is the dimension from the end of the T/T to the crossmember.
gary
gary
garyw- Posts : 6
garyw wrote:I bought one off of ebay shipped for $50.00 so they are out there.
I know they're out there, I just didn't start looking to buy one until about 5 hours ago.
gary
Good question. We didn't get a very good dimension on that. It was between 16" and 18", I think, but we're more interested in letting the parts do the talking at this point. The car isn't in my garage and the crossmember is unbolted anyway, so I can't really check. I'll have a better idea once I get that bellhousing.
im glad somebody is doing a ford conversion. im a ford guy to. i have a 351w long rod sitting in my garage. maybe after i do my ls1 swap ill look into buying another and do a ford one. would take more fab work tho thats for sure.
Im really surprised they got a mod motor in there. those damn things are so wide. the older ones shouldnt be as wide so a little easier fit maybe?
shokwave30- Posts : 68
» Early 944 Ford 5.0l conversion
» Hydroboost fitting help
» Ford Hydroboost to Porsche 951 Master Cylinder Adapter
Page 1 of 4
