944Hybrids
Welcome to our forum.
» Pacific Raceways near Seattle
Today at 7:26 am by Lemming
» HELP . . . Electrical gremlin
Today at 12:01 am by Rich L.
» Rich's LS powered 944 track car
Yesterday at 8:59 pm by Lemming
» First Time Swap 85 Porsche 944 to LS6
Yesterday at 7:03 pm by kjducati
» Oil and steering cooler options
Yesterday at 6:11 pm by docwyte
» selling conversion parts due to new baby
Yesterday at 4:29 pm by zeusrotty
» Strut brace?
Mon May 14, 2012 5:38 pm by fliermike45
Mon May 14, 2012 1:56 pm by epsylon9mm
» building a 1983 948 on a budget - pointers?
Mon May 14, 2012 7:19 am by Admin
» To " badge or not to badge "
Sun May 13, 2012 5:01 pm by 944-LT1
May 2012
78910111213
14151617181920
21222324252627
28293031
Heat Shield / Sound Deadening
Post  Bluemach1 on Sun Aug 01, 2010 9:24 am
Any recommendations for affordable heat shield and sound deadening material? I know dynamat, fatmat, B-quite for sound. Any others that work as well but cheaper?
What about heat shield? I have to run the stock cats for Cali compliance, They will be almost right under the drivers and passengers feet. I need to laydown something so feet dont get toasted.
Took all of the old stuff out this weekend. The sticky, gooey, old stuff from the old carpet, sound mat removal was a a real PITA to removel.
Bluemach1
Re: Heat Shield / Sound Deadening
Post  944-LT1 on Sun Aug 01, 2010 11:21 am
Pegasus racing sells all the good stuff.....They also sell the NASA type gold reflective film if youre real serious! The big problem is the undercoating on these cars. Its thick and may melt with heat (fire?) if you dont scrape it off or make a shield like the mufflers.
Best and cheapest is aluminum sheet>fiberglass sheets>aluminum sheet above the cats. Or, simply install one cat in the stock location???
Post  948 on Sun Aug 01, 2010 5:29 pm
As Michael mentioned for the body-to-exhaust heat shield, use the AL/FG/AL sandwich. See my post on PH board from 4 years ago. Shocked
"For the body;
I made a heat shield for the drivers side of the engine bay. I don't have any pics in my album. The shield covers all of the frame and strut area, just like the stock passenger side.
I picked up a couple of sheets of annealed Al, from McMaster, and a roll of fibre glass fabric. I then made a sandwich of Al/Fibre glass/Al. I can't recall the exact width and length (~12"x24" I think). I rivited these together and then beat it (soft blow mallet) to the shape of the rails and strut tower. I added some slits to clear the boxed sections on the strut tower. I trimed the extra and drilled locating holes thru the shield into the frame. Threw some cosmoline in the holes and then rivited it to the body.
I bought: Alloy 1100 Annealed Aluminum Sheet .032" Thick, 36" X 48" from Mcmaster"
Post  944-LT1 on Sun Aug 01, 2010 6:53 pm
As Michael mentioned...
I remembered that post when I posted above! Laughing ....Ah, were synced. Cool
Post  xschop on Sun Aug 01, 2010 7:37 pm
Can't beat the $3 heat shield.... 3 aluminum turkey bake pans (thick Al.) from Dollar Tree sandwiched together.... Just waiting on my 13/16" Master Cylinder to show up so I can put in on the Dual MC set-up then make the shield. Very Happy
As for sound deadening. I have used 30# roofing felt and brush on roofing tar in some vehicles. I may pull that trick out of the hat when I put my subs in the spare wheel well.
Post  948 on Sun Aug 01, 2010 8:46 pm
But did you remember that it was 4-1/2 years ago? Shocked
Post  944-LT1 on Sun Aug 01, 2010 9:19 pm
Nope! Seems like yesterday....................................................................were getting old. Laughing
