Which radiator do you use?
+7
MN944S
endrnet
Vorsche944
Wild Bill
GudmundurGeir
11 posters
Which radiator do you use for the ls1. Original 944 is to small right?
GudmundurGeir- Posts : 45
Re: Which radiator do you use?
I don't know how others feel about the issue, I purchased my radiator from Renegade and it works good to keep the engine at temp. It comes with a fan and relay for it too. Its all allimnum welded. Pretty and light.
Also it fits within the radiator thickness. The only modification needed is to drop the support bar, with their instructions it says all you have to do is use longer bolts. I wouldn't know that for sure though, My radiator support had been modified by previous owners.
I used a Griffen, modified upper sheet metal. didn't drop lower mount. I didn't like the idea of taking out a radiator going over a speed bump. It's this one... [You must be registered and logged in to see this link.]
Rad cap is now sealed with aluminum disc epoxy'd in and rad cap installed over top.
I added the 1/8" X1" angle iron to the front because I felt the hood release could be a little stiffer after cutting away sheetmetal for clearance.
Wild Bill- Posts : 121
I use a stock radiator from Summit. We use the 944 fans.
We also modified the front cross member, moved the radiator up front 4" to get more room.
So far working great.
I'm using the same summit racing one although it looks like it went up $20 in price since I bought mine.
I had my favorite local machine shop (they are apparently famous for their work on jeeps, some kind of rock crawling nonsense) cut off the cap area and alum weld a plate over it.
Planning to do the same forward movement that Vorsche did, although I'll be darned if I can figure out where his fancy pants bolts came from.
endrnet- Posts : 129
Question for Vorsche or Admin:
On Vorsche's car (pic above) are you using a fabbed crossmember between the bumper mounts or running without?
MN944S- Posts : 32
I/ we are using one of my fab'd crossmembers.
It's about half way down the page.
I havent purchased anything yet but I stumbled across these... Pricey!!
The bolts I'm referring to are the ones on top that are threaded only in the middle. I think I understand how they work but I'm not 100%. Looks like either they threaded into a bolt welded to the angle iron or the nut is underneath and held with a wrench while you tighten the bolt, thus applying pressure on the metal plate at the bottom of the threads.
I took a stock type bolt and removed about 1/2" of threads from the end of it. There is a nut welded to the top plate that the bolt threads through, then there is a lock/jam nut under the top plate. The end of the bolt goes through a small metal plate with a hole in the center which sits on top of a rubber pad with the same size hole in it, That keeps everything in line. With just a little tension from the bolt everything stay put. Basically the same idea as the factory setup, just a modified version.
I use a stock 951 radiator. So far, so good! I blew up my original one, so i got a new one on ebay for $100 and paid a radiator shop $40 to clean it.
Is there a preference between these 2 that are referenced on this page?
The summit radiator (23.875 in. Wide, 16.0 in. High, 1.75 in. Thick) is -1/8" on width and -1.25" on depth compared to the griffin one (24 in. Wide, 16 in. High, 3.0 in. Thick), so it takes up less space- would it provide better cooling than a 951 radiator?
Thank you guys
Do you think it's nessecery for my..? I'm located in Iceland. It's relly cold here hehe
I thought Greenland was cold and Iceland was green?
Dawgz83948- Posts : 603
