Today at 6:37 am by Patb
» 5.3 conversion on 88 Turbo
» Clutch Issues - HELP!!!
» Hydroboost Lines from TPC
» 1984 Gen IV 5.3 Swap
» Dry Sump Oil Pan Fitment
May 2018
78910111213
14151617181920
21222324252627
28293031
Which radiator do you use?
Post  GudmundurGeir on Sun Mar 07, 2010 3:52 am
Which radiator do you use for the ls1. Original 944 is to small right?
GudmundurGeir
Re: Which radiator do you use?
Post  cfgioja on Sun Mar 07, 2010 9:36 am
I don't know how others feel about the issue, I purchased my radiator from Renegade and it works good to keep the engine at temp. It comes with a fan and relay for it too. Its all allimnum welded. Pretty and light.
Also it fits within the radiator thickness. The only modification needed is to drop the support bar, with their instructions it says all you have to do is use longer bolts. I wouldn't know that for sure though, My radiator support had been modified by previous owners.
Post  Wild Bill on Sun Mar 07, 2010 1:47 pm
I used a Griffen, modified upper sheet metal. didn't drop lower mount. I didn't like the idea of taking out a radiator going over a speed bump. It's this one... [You must be registered and logged in to see this link.]
Rad cap is now sealed with aluminum disc epoxy'd in and rad cap installed over top.
I added the 1/8" X1" angle iron to the front because I felt the hood release could be a little stiffer after cutting away sheetmetal for clearance.
Wild Bill
Post  Vorsche944 on Sun Mar 07, 2010 4:38 pm
I use a stock radiator from Summit. We use the 944 fans.
We also modified the front cross member, moved the radiator up front 4" to get more room.
So far working great.
Vorsche944
Post  endrnet on Sun Mar 07, 2010 7:44 pm
I'm using the same summit racing one although it looks like it went up $20 in price since I bought mine.
I had my favorite local machine shop (they are apparently famous for their work on jeeps, some kind of rock crawling nonsense) cut off the cap area and alum weld a plate over it.
Planning to do the same forward movement that Vorsche did, although I'll be darned if I can figure out where his fancy pants bolts came from.
Razz
endrnet
Post  Admin on Sun Mar 07, 2010 8:56 pm
Which bolts are you referring to? I built all that.
Post  Vorsche944 on Sun Mar 07, 2010 9:46 pm
yes he did. All his work is like that. NICE
Vorsche944
Post  MN944S on Mon Mar 08, 2010 9:06 am
Question for Vorsche or Admin:
On Vorsche's car (pic above) are you using a fabbed crossmember between the bumper mounts or running without?
MN944S
Post  Admin on Mon Mar 08, 2010 10:05 am
I/ we are using one of my fab'd crossmembers.
It's about half way down the page.
Post  Bluemach1 on Mon Mar 08, 2010 7:53 pm
I havent purchased anything yet but I stumbled across these... Pricey!!
Bluemach1
Post  endrnet on Mon Mar 08, 2010 8:49 pm
The bolts I'm referring to are the ones on top that are threaded only in the middle. I think I understand how they work but I'm not 100%. Looks like either they threaded into a bolt welded to the angle iron or the nut is underneath and held with a wrench while you tighten the bolt, thus applying pressure on the metal plate at the bottom of the threads.
endrnet
Post  Admin on Mon Mar 08, 2010 9:01 pm
I took a stock type bolt and removed about 1/2" of threads from the end of it. There is a nut welded to the top plate that the bolt threads through, then there is a lock/jam nut under the top plate. The end of the bolt goes through a small metal plate with a hole in the center which sits on top of a rubber pad with the same size hole in it, That keeps everything in line. With just a little tension from the bolt everything stay put. Basically the same idea as the factory setup, just a modified version.
Post  Porch on Tue Mar 09, 2010 9:28 am
I use a stock 951 radiator. So far, so good! I blew up my original one, so i got a new one on ebay for $100 and paid a radiator shop $40 to clean it.
Post  subterfuge on Wed Mar 31, 2010 4:25 pm
Is there a preference between these 2 that are referenced on this page?
The summit radiator (23.875 in. Wide, 16.0 in. High, 1.75 in. Thick) is -1/8" on width and -1.25" on depth compared to the griffin one (24 in. Wide, 16 in. High, 3.0 in. Thick), so it takes up less space- would it provide better cooling than a 951 radiator?
subterfuge
Post  GudmundurGeir on Wed Apr 07, 2010 8:58 am
Thank you guys Smile
GudmundurGeir
Post  Guest on Sun May 02, 2010 12:29 pm
Thanks for all the help, as well.
Guest
Guest
Post  GudmundurGeir on Fri Jul 09, 2010 2:40 pm
Do you think it's nessecery for my..? I'm located in Iceland. It's relly cold here hehe Very Happy
GudmundurGeir
Post  Dawgz83948 on Fri Jul 09, 2010 3:15 pm
I thought Greenland was cold and Iceland was green?
