1987 Porsche 944 LT1
Finally got an old video up on youtube, so i can show you guys!!! Since this vid, i have completely repainted the car, put the stock hood back on, shattered a cv joint, swapped a transmission, and begun completely rewiring the engine...
v8944- Posts : 211
Re: 1987 Porsche 944 LT1
On my car the oil filler is very tall sits way above the valve cover. Are those new valve covers with a flush filler or can you get a replacement filler that sits flush like yours?
One more question... My drivers side header flange is going to hit the frame of my car. Did you have to hit that side in at all so your header fit?
Thanks! Your car sounds good!!
I had to do that on my LS1 on the driver side since it has a factory bow out in the frame rail. Glad to know I am not alone in that area.
I don't think I could get a sledge in there to smash it and I want to avoid removing the engine.... Could I use something like a small hand held electric jack hammer? Can you get them with blunt ends?
when i replaced my header gaskets (recently) i beat in the header around the collector to give myself a little breathing room, it helped tremendously.
My car had a very high oil filler like yours i would guess. i unscrewed the cap from the top, then unscrewed the filler neck, then screwed the cap straight into the valve cover, worked like a champ!
v8944- Posts : 211
Thanks, I didnt know you could do that....
I managed to get my header to fit. I beat the frame rail in last night with a piece of pipe and a BFH. What headers are you using? I'm using sanderson headers and I think I remember reading on the sanderson site that your susposed to use just RTV sealant and no gaskets?
i don't know about sanderson's, i'm using patriot tight tuck headers, they're essentially the same thing, just cheaper...
v8944- Posts : 211
I am looking to use the patriot truck headers do you have a parts number and did you have to mod them. Sorry for the stupid questions
airheadhubs- Posts : 5
These headers are only for LT1's if you plan on using a 5.3L LSX; you'll have to get them modifed to fit.
» FS: 1987 Porsche 944 Turbo
» Free 1987 Porsche 944s body W/Title
» 1987 porsche turbo brake calipers, and front rotors. $350.00 shipped
