» 4.8 Ls beast!
1987 N/A Build EmptyYesterday at 5:07 pm by yamamtx
» RX7 oil cooler installation
1987 N/A Build EmptyYesterday at 8:24 am by gwistrup
» PORSCHE 944 5th-0.68 , other gearbox parts GOT all you need!
1987 N/A Build EmptyMon Apr 06, 2020 12:51 pm by Martynas
» 86 Porsche 944T LS1 swap begins
1987 N/A Build EmptySun Apr 05, 2020 10:15 pm by smkn951
» Set of Wilwood big brake adapters
1987 N/A Build EmptySat Apr 04, 2020 5:35 pm by scryfst
» RX7 Caliper swap adapters
1987 N/A Build EmptySat Apr 04, 2020 5:21 pm by scryfst
» Ford Windsor engine swap
1987 N/A Build EmptySat Apr 04, 2020 12:00 pm by haroldk
» C5 Transmission and TT?
1987 N/A Build EmptyThu Apr 02, 2020 2:25 pm by spence
» looking for 944 v8 conversion manual
1987 N/A Build EmptyWed Apr 01, 2020 3:28 am by spence
» 944 S2 - LS3 & T56 Conversion
1987 N/A Build EmptyTue Mar 31, 2020 11:09 am by Slpr948
April 2020
6789101112
13141516171819
20212223242526
27282930
1987 N/A Build
1987 N/A Build Empty 1987 N/A Build
Post  spencerorme on Mon Aug 19, 2019 6:40 pm
We have already begun our build and we wanted to share where we have been where we are.  Any suggestions is appreciated Yes we know we should have painted it after but due to painter conflicts we had to get it in when we did.  It is a 1987 N/A that was really messed up.  The more we tore down the more we have found.  We have requested a manual and have not received one yet so everyone Thank You in advance for all of your help and support.  Our goal is to build a quality road going, autocross and maybe a track day car with A/C due to VA heat and humidity.  While at it make it reliable but most of all fun. Not flashy.[You must be registered and logged in to see this link.]
This is what we started with.[You must be registered and logged in to see this link.]
spencerorme
1987 N/A Build Empty Udate on project
Post  spencerorme on Mon Aug 19, 2019 6:46 pm
Project update Porsche Atlas Metalic Grey and engine swap moving forward.[You must be registered and logged in to see this link.]
spencerorme
1987 N/A Build Empty Today Aug 19th
Post  spencerorme on Mon Aug 19, 2019 6:48 pm
Just put in steering rack will post pics tomorrow
spencerorme
1987 N/A Build Empty Re: 1987 N/A Build
Post  player_1 on Wed Aug 21, 2019 11:41 am
looks great! keep it coming
player_1
Post  Plucky948 on Sat Aug 24, 2019 7:11 am
Nice fan setup, are those 10" fans on a custom shroud? Are you wiring relays from the gm fuse box or stock Porsche box?
Plucky948
Plucky948
Post  spencerorme on Thu Oct 03, 2019 10:20 am
From the Porsche side
spencerorme
Post  spencerorme on Thu Oct 03, 2019 10:31 am
Those are ten inch fans.  Lots of work going on.  Engine bay was ceramic coated and sound deadened prior to installation.  We took engine out from top and was no problem.  Rebuild and coated cross member have rebuilt steering rack working on shock mounts top and bottom now.
spencerorme
1987 N/A Build Empty following
Post  smkn951 on Thu Oct 03, 2019 7:10 pm
watching this closely. i'm hoping you may post how you're doing the wiring harness. really looking forward on how you're going to do the a/c.
are you modifying the ls harness or going with a manufactured one?
smkn951
smkn951
Post  spencerorme on Sat Mar 14, 2020 3:36 pm
spencerorme
Post  spencerorme on Sat Mar 14, 2020 3:37 pm
spencerorme
Post  spencerorme on Sat Mar 14, 2020 3:42 pm
spencerorme
Post  spencerorme on Sat Mar 14, 2020 4:00 pm
spencerorme
1987 N/A Build Empty Engine in wiring run hoses run minus a/c that will be last
Post  spencerorme on Sat Mar 14, 2020 4:08 pm
spencerorme
