project continues
+10
laptop_geek
adam7e
Luke714
skywalker01
a951
14 posters
Page 3 of 3
Page 3 of 3 • 1, 2, 3
Re: project continues
a951 wrote:After finishing at garage at 22:30 localtime I went straight to a friends party, and showed this on the bigscreen, nobody understood it, and they were not all that impressed... doh.
Haha ..... I have friends like that. Don't worry, we understand.
damnit, I managed to plumb the oilfilter in & out the wrong way, in my haste to find if there was any leaks, K&N filter, could it do any damage? im guessing the filter has some sort of 1 way function, but engine seems to get oil pressure fine, and no lifter noise, engine noise etc.
a951- Posts : 121
I found another filter and viewed it, seems it will flow plenty both ways.. so thats good.
I finished up thermostat, oil filter, oil cooler an plumbing, its handy to have a LOAD of fittings laying around from my glory days..
pics from sump change
starting hosework and figuring out placements.. what an utter pain in the .. arse!
a951- Posts : 121
tested the lines, had to tighten 2 of them a tiny bit, and the one I had forgotten to tighten at all, then no leaks, tada!
now, I got my tick performance remote bleeder today, nice piece of kit, trouble is.. ever tried mounting one while engine and torquetube and tranny is in?! impossible, I got it all the way in, washer and all, just cant tighten it, no matter what I try... soooo I get to pull the tranny, TT and remove the clutch cyl from the clutch housing. not that much jub.. but hey annoying
a951- Posts : 121
Hold on...
Porch had to do the same thing. 8th post down, See here... [You must be registered and logged in to see this link.]
Did not require any grinding with my RH parts. I did have to take a 7/16 deep socket and cut a side off of it to tighten the hose onto the fitting. It was a slight PITA, but bleeding is now so easy that the memory will quickly fade!
I did fit it without any grinding, I just cant tighten it :/
thanks for the tip, I asked in his thread.
a951- Posts : 121
I removed tranny, torquetube, rearend of clutchhouse.. just to tighten the bugger.. not that time consuming really.
tring to mount the damn adapter plate for master.. now thats a BITCH!!!! then bending the lines to fit.. what an utterly non enjoyable job.
sorry about bad cellphone pics
a951- Posts : 121
You know that you can rotate the fuel rails 180 degrees and get rid of all that extra hose?
Admin wrote:You know that you can rotate the fuel rails 180 degrees and get rid of all that extra hose?
I do, but its actually a better fit with the fuelreg and its position where it is
not to happy with the brake solution, but I just cant find a source for tandem cylinders with tandem bars as xschop stopped selling his, and kokelns availability/fit with v8 is unknown.
going to mount the new tranny mount and bleed system this week,
a951- Posts : 121
Im using a RH kit, which supplies spacers for the transvers.
Have I got this correct when thinking that spacers are only there to improve hood clearance? or is there something else as well?
I will most likely just do a fiberglass hood regardless, so a small buldge is very easy to make into the mold.
a951- Posts : 121
sooo my other tranny mount, has the mount sitting to far forward, and my last has it sitting to far back.. doh
guess I need to buy another one.
I also removed the spacers on traverse, now thats a CLOSE fit everywhere now, but Im much more happy with it than having spacers everywhere, also this doesnt ruin A arm geometry.
a951- Posts : 121
well, finally botherd working on the car
so mounted tranny, drive shafts, exhaust on again, A arms, Spindles, shocks, steering rack, taped up harness, mounted in oem locations, made a ECU mount in passenger well, routed cables there, finalized the relay/fuse box, mounted with ecu..
now I just need to decide on suspension, and save up, buy a turn one pump, and plumb the turn one...
a951- Posts : 121
made this yesterday, and pulled it from mold today, wonder how it will clear I used divnicell, to brace, and no brace around where it "should" rub on TB, wil maybe get time to test tomorrow. we will see.
a951- Posts : 121
Page 3 of 3
