944 Billet-Polyurethane Transmission Mounts....PM for Details
+19
thedge
psnyc
kachunk
LEEEZARD7
beario
supersport
cjbcpa
marc a
Max Energy
chadfjones
kelleysj
Tehone
a951
joeytoad83
23 posters
Page 2 of 3
Page 2 of 3 • 1, 2, 3
Re: 944 Billet-Polyurethane Transmission Mounts....PM for Details
I have no slotting in my X member, its stock unmodified.xschop wrote:So are you saying you would need the V8 mount that sets the engine back or do you need the regular one because your trans X-member has been slotted?
so either I need a mount that puts the trannymount a few mm backwords, or slot it.
so yes, I guess I need the v8 mount as you call it
a951- Posts : 121
Re: 944 Billet-Polyurethane Transmission Mounts.. early 84'
xschop,
You were working on the early 2-piece mounts. Still have some.
I purchased an 86' (01-20-86) 944 turbo 5-spd with the cross member. The 84' doesn't have the removeable transmission cross member and now find myself without mounts.
Do I need to first find a pair of the transmission side mount plates for the early style 2-piece, and then the rubber mounts if there are no other options?
The car had an auto that is being swapped out and still have those but unless I was not seeing correctly the metal side plate didn't match anywhere I thought it would bolt to.
Any thoughts
Any thoughts
Tehone- Posts : 84
I have 2 sets left of the EARLY 2-piece. I have only seen the drawings of the automatic side plates, but thought they could be modded to fit. I know that the Early MANUAL side plates will fit the late boxes and one of the holes is missing from the ddriver's side IIRC, but can be drilled easily.
Man i wish i would have gotten this instead of the lindsey ultra mount i would of helped you and saved money as well.
kelleysj- Posts : 194
The Lindsey mount has rubber bushings.
I know thats why your mount is a better product!
xschop,
Still have a set of your trans mounts for an early 944?
If so I'll take them!
chadfjones- Posts : 13
Yes, I have a couple sets left. I'll send PM.
Can't PM a newbie I guess....
If in U.S. Paypal $206 ($216 Canada) to:
I'll get them out Monday morning priority.... Thanks, Rob
I have only 1 regular LATE mount left with all hardware/bushings until I can make some more, which won't be for another 3-4 weeks. I will ship it for $188 anywhere in the U.S.-48...Just PM
944 trans mount
Rob,
Do you have any of the late 944 trans mounts available?
This is not being used on a V8 car, this is a 2.7 dedicated track car.
Max
Max
Max Energy- Posts : 34
Hey Max, I am finishing a few Regular/Late mounts on the CNC and can ship one Mon or Tues, depending on the place where I get the hardware and shoulder bolts.... And I will let it go for the same $188 shipped to the US-48
I'll have 2 more left if anyone else is interested. Just Paypal $188 to...... [You must be registered and logged in to see this link.]
Trans Mount
Rob,
I will take one. I am out of town until tuesday, lets see if we could have it ready to ship by wednesday.
Max
Max
Hey Rob, did you tell me that this limit transmission travel?
Dawgz83948- Posts : 603
Yes, there is less than 1/16" side-to-side trans movement when locked down and still isolates vibes/noises. I'll have another batch done in 2-3 weeks as I am sold out ATM.
xschop wrote:Yes, there is less than 1/16" side-to-side trans movement when locked down and still isolates vibes/noises. I'll have another batch done in 2-3 weeks as I am sold out ATM.
PM me, I'll try to sneak it under the wifes radar.....
Rob,
This mount is awesome. I'll post a link to this thread on our local Porsche board.
Marc
Marc
marc a- Posts : 170
Finally got them installed a couple weeks back. Along with trans fluid change, now
shifting much better than before.
Orig mount passenger's side
New mount passenger's side
Orig mount driver's side
New mount driver's side
Hey Chad,looks great. How much could you move the trans side-to-side before the poly mounts?
I think it felt like about 1/4 to 1/2 each way but didn't measure it.
I'm re-doing the rear suspension on my Turbo track car this winter. Can you PM me or make an announcement when you have more late model mounts available? Might as well plan/prepare for my swap now while I can!.
CB
CB
cjbcpa- Posts : 60
Sorry for the late reply. I will have some done in 3-4 weeks and the late mounts will be a new 2-piece design where you can undo 2 bolts and have a factory setting or V-8 swap set-back setting. My billet hubs are finally up next on the CNC for programming. The pot-holes are mini-craters around here lol.
OT but do you still looking for some late struts to see if you can make them rebuildable with KYB, etc., inserts?
acorad- Posts : 697
You can make late struts rebuild-able with the koni hacksaw method.
» Early 2-piece Billet Polyurethane tranny mounts (83-85)
» Transmission mounts: To upgrade, or not to upgrade.......
» Headed to Paint Today
Page 2 of 3
