968 rear glass
+7
Bluemach1
ffmedic
m73m95
11 posters
968 rear glass
Has anyone installed the rear glass with the wing from the 968 on the 944?
Or can just the wing be installed on the 944 rear glass?
Re: 968 rear glass
Admin wrote:Has anyone installed the rear glass with the wing from the 968 on the 944?
Have not but I've read that they are compatible.
Dawgz83948- Posts : 603
Re: 968 rear glass
Do you think it would be as simple as replacing the trim around the rear glass and installing the wing?
Re: 968 rear glass
All three pieces, stock 968, will bolt right up to the 944 glass....IIRC
Re: 968 rear glass
That's the route I am going already got the wing.
Not the glass but the wing that is.
I believe they are compatible.
ffmedic- Posts : 103
Re: 968 rear glass
I bought a fibreglass replica from a guy in the UK. Nice quailty.
Mike
Mike
Re: 968 rear glass
Bolts in the same holes as the original rubber spoiler. I don't have it installed yet, but will try to get a pic of it. Main difference is no 3rd brake light, but that is taken care of already in the stock setup.
Mike
Mike
Re: 968 rear glass
FYI -
I found this write up regarding transplating a 968 spoiler onto a 944.
Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 924/931/944/951/968 Forum
TOPIC: 968 spoiler transplant on 944 : Work in progress
BTW - I think that the 968 spoiler looks very very cool but does it offer any functional property?
Re: 968 rear glass
While searching one of the forums, rennlist or pelican, I found a thread that showed a 968 wing that was made to adjust in the center section with a little more rear lip. I will see if I can find it again.
Rear Wing
The rear spoiler referred to above is the 968 Turbo S wing. OEM is VERY pricey if you can find one. Several vendors out there making FG and CF replicas.
968gene- Posts : 259
Re: 968 rear glass
FG Fiber Glass
CF Carbon Fiber
WTF - What the f***
BTHOM - beats the hell out of me
Don't you just love acronyms
CF Carbon Fiber
WTF - What the f***
Re: 968 rear glass
Salut eric regarde ce lien en bas de page , c'est de la fabrication francaise "good" sans la moindre modif , ils font des PC avant et arrière look 968
si tu veux des précisions je leur demande pas de problème
Joe- Posts : 62
» Rear hatch glass on 944
» WTB: Porsche 944 Glass Sunroof
» PorVette with full Vette drivetrain and rear suspension
