» Transaxle rebuild
» Tpc LS adapter plate
Rear Hatch Glass Re-Glue??
Post  Bluemach1 on Wed Nov 17, 2010 8:52 pm
Well, continueing from my earlier post "Leaking Lights", I replaced the seals around the tail lights and water tested with sucess. However, what I found is that the rear hatch is leaking at the seam around the glass on both sides right about where the glass makes the bend to follow the body contour. I was wondering if re-glueing the frame to the glass is a do-it-yourself project or if I should find a shop to do this for me. I dont know if this is a job for one of those "fix your widow from a van" guys.
Opinions??
Bluemach1
Re: Rear Hatch Glass Re-Glue??
Post  Admin on Wed Nov 17, 2010 9:10 pm
If you have a local auto glass shop, just stop in and speak to one of their field techs, They will give you the best answer. You might be able to just by some "Professional Grade" black poly urethane and reseal it yourself. That's what I would do, but you know me..............
Post  laptop_geek on Wed Nov 17, 2010 11:20 pm
If you decide to do it yourself here is a good write up.
laptop_geek
Post  cfgioja on Wed Nov 17, 2010 11:51 pm
I did something similar to mine where the top edge had came unstuck but instead of pulling the whole metal strip off I managed to squeeze some Black window sealer in it and got it pressed back together pretty good. So far it hasn't come back off. Its been about 7 months now.
Post  v8carreragts on Wed Nov 17, 2010 11:54 pm
Just use 3M window weld urethane adhesive. You can buy it at Auto Zone or Advance Auto.
