LS1 ECU file needed
LS1 ECU file needed
Greetings all. Need some guidance/assistance here please. Have an 89 with LS1 2000 that I waS eventually able to get started. I have spent months wiring and trying different files to get this thing to idle. I have no idle control and issue seems to point to TPS which > verified wiring and replaced TPS. Is there anyone that is able to share a base ecu file for ls1 with drive by cable that has been proven? Help is greatly appreciated. Thanks
hlricks- Posts : 23
RE;PCM files
I used an on line tuner to put the base tune in my PCM. The company was pcmofnc.com. You have to have HP Tuners to email them your existing tune. You also have to fill out a form that describes your engine. They will send you a tune that will get the car running well enough so you can make a recording of specific engine parameters. Send them the recording and your tune back with a description of how the engine is running and they will make adjustments to the tune to get the engine running correctly. I have sent my tune back twice and the car is almost there.
The PCM tuning process is incredibly complicated and to try to do it without any experience can be very frustrating. I also would recommend going to the hp tuners website to read up on some tuning basics. There are mountains of information there. I discovered that my engine had several problems with the IAC, base idle, and canister purge system that needed to be corrected before trying any more attempts at tuning the PCM.
There are several on line tuners out there. I had good luck with pcmofnc.com. Their fee is worth it for the time it will save you. Good luck, Gil
gwistrup- Posts : 113
hlricks likes this post
Re: LS1 ECU file needed
I have the car running and if I disconnect the TPS, the car idles great at 900 RPM. I am even able to step on the gas and control the rpms up and down. When I reconnect the TPS, the idle shoots up to 4-5K. I have a tuner that allows me to make changes. What I need is a working baseline file that is setup for drive by cable. With that I can tune the car as needed. I just need to stop downloading files with no idea of their true reference and configuration. Thanks for the recommendation you gave. Much appreciated.
hlricks- Posts : 23
Sounds like you need to configure the correct throttle body parameters in the tune file.
Leva- Posts : 82
Liva you are most likely correct. I appear to be lacking in the "configuring" process. Lol. Which is unusual because I work in the IT field. I was hoping that someone had a "fully functioning" file that they were willing to share where this issue was already addressed (it never hurts to ask). I have been trying to resolve so many electrical issues on this car created by the previous owner that I have been unable to focus on this one. I have downloaded a bin bile to get the car started and running but still need to get it to idle without issues. As previously stated, I have checked all wiring but I am not sure if that is the issue or the file I was recommended to download. Was hoping someone here had the "correct" parameters already and was willing to share the file. Thanks much for your response.....
hlricks- Posts : 23
If you are using HP Tuners, then go to their website and you can find stock tune files. You will have to create an account on HP website, but it's free. You can then download that file, and then copy/paste the parameters you need. If it's a different tuner, then I'm not sure. Basic parameters should be the same. Just depends on how the tuner reads it.
What ecu are you using? if it's the 2000 LS1, it should have the correct info for DBC.
Do you have access to hptuners. If so, you can load the scanner and check tps function. With koeo, and accelerator position parameter channel logging, you can see what tps is doing as you press the gas pedal and verify voltage/opening percentage. That would rule out mechanical issues with the tps. Or, you can just use some jumpers and a voltmeter. After that, i would verify which throttle body you have. Any idea what the donor engine came out of? Camaro, Corvette etc? I believe the corvette ls1 came with a slightly bigger tb. If you downloded a baseline ls1 tune from a camaro and instead have a corvette donor engine, you would have to adjust the etc scalar figures in the tune file to accomodate the bigger throttle body. Ultimately, i would verify what engine and ecu you have, and then download the appropriate baseline tune. Like Hotrodz said, hptuners.com has any baseline tune you should need. If you start with the wrong tune, you will be chasing your tail with more then tb issues. Injector sizing, map sensor, maf etc numbers can be off.
Leva- Posts : 82
Today at 4:44 pm by JW1970
Today at 12:39 pm by Nath1142
