» Transaxle rebuild
» Hello, Gentlemen.
Yesterday at 7:43 pm by rawr
» alignment specs
HP Tuners HPT file for tuning
Post  money pit 951 on Wed Jun 26, 2013 9:29 pm
Got the car together and hope to get it back on the dyno soon. Purchased a copy of HP Tuners and found that the ECU/PCM is from an automatic and spitting out a lot of error codes for the trans. The system is not going into closed loop and I think the trans errors are preventing this.
I'm wondering if anyone else here has a copy of HP Tuners and could post their HPT file. I suspect I might have to do a segment swap to get it looking like a manual trans, but would also like as starting point basic tune from what people are running.
Anyone have a copy and mind posting their files?
money pit 951
Re: HP Tuners HPT file for tuning
Post  zeusrotty on Thu Jun 27, 2013 4:00 pm
hp tuners has a forum for these questions. You would probably get a better and more accurate response there.
zeusrotty
Post  87-944S on Thu Jun 27, 2013 8:48 pm
1st save a copy of your ECM, then go into the engine DTC codes and disable all for the the transmission. BTW, since you have an auto ECM, the VSS settings should be right, if you are using a 40 tooth trigger wheel. HPTuners forum is awesome, join if you haven't. Very Happy
Post  Admin on Thu Jun 27, 2013 9:21 pm
I use HP all the time, just turn off all the trans codes as mentioned before and make sure you disable the torque management if there is any.
Post  money pit 951 on Sun Jun 30, 2013 9:41 pm
Thanks guys. Just got the car running, so will start to play. Didn't realize I could just disable the trans codes. Have a lot of learning/playing to do
What does VSS stand for?
money pit 951
Post  Admin on Sun Jun 30, 2013 10:08 pm
Vehicle Speed Sensor
