Air Conditioning A/C compressor
anyone have A/C on there LT1 conversion?
any clearance issues or needed modifications i should know about before adding the A/C back on mine?
Last edited by jerry944 on Sun Aug 14, 2022 10:07 pm; edited 1 time in total (Reason for editing : added)
jerry944- Posts : 9
Re: Air Conditioning A/C compressor
If you are referring to a Gen II LT engine, using F-body accessory bracketry - you will need to dish the frame rail where the compressor sits, mainly for pulley clearance.
yes that is exactly what i am talking about 1995 Z28 LT1....
does anybody have a picture of this area showing the clearance modification ?
jerry944- Posts : 9
Search through my old posts, I believe there was one.
My car also has a '95 Z28 LT1. It originally had A/C when it was built years ago, but the previous owner removed it when he turned it into a track car. I'm planning on reinstalling A/C one day.
The passenger side frame rail was hammered on, cut, and welded as shown below. It appears the modified area is too far forward to line up with my belts, but I haven't seen an LT1 compressor yet in person so I'm not sure how the pulley looks.
Rob44- Posts : 35
MuhThugga- Posts : 15
