Don't know what this is
Can somebody tell me what this is And if I can remove it[You must be registered and logged in to see this image.]
Michael Bivins- Posts : 20
Re: Don't know what this is
Fuel tank vent system
Can I remove it and do something different
I know some people remove it, but I prefer to keep it intact. Only requires a simple vacuum hookup to the engine.
Thanks for the information
Can you put 87 Turbo Evan Turbo break calipers on 1985 NA944
RE calipers
87 Turbo calipers came from a late offset car and I believe your 85 944 NA is an early offset vehicle. They won't bolt directly onto your car without some changes. The calipers are the same between a late and early offset vehicle but all of the other components are different. Therefore you will need to change your rotors, hubs, spindles and struts to convert to the Turbo brakes.
gwistrup- Posts : 113
Today at 12:39 pm by Nath1142
