SELLING MY BABY! LS1 SWAPPED 951
1988 951 about 120k on chassis
interior is 8/10
seats are near new
-02 LS1 with 60k on engine prior to build
-LS6 intake (port matched)
-FULLY WORKED 241 heads
-2013 Denali Flex Fuel injectors
-Custom grind cam (226/230 .598/.599 113 LSA)
-TEA dual springs w/titanium retainers
-Comp Cams Trunion Upgrade
-TPC Custom Ceramic coated long tube headers
-TPS install kit
-larger 4-core aluminum radiator
-NA 5th gear swap
-C5 2-piece bell housing
-SPEC Stage II clutch
-Fidanza lightweight flywheel
-ATI Super Damper
-SLP Double roller timing chain set
-ported and polished MAF and 78mm throttle body
-Wilwood remote master cylinder
-Mustang Cobra remote master cylinder
-custom exhaust w/Magnaflow muffler
-18" MODA R6 wheels
-new tires Michelin Pilot Super Sports on the rear.
Texas Performance Concepts completed the build to include the brake lines and electrical work.
I no longer have the time for this car. Wife won't let me spend anymore money on it since I started building a 67 C10. No power to the OBD port after new injectors, fuel pump, and starter were installed. My loss is your gain. Ran like a beast and put down almost 400rwhp. Call or text for pics and further information 601-624-9440.
$15,000
interior is 8/10
seats are near new
-TPS install kit
-NA 5th gear swap
-ATI Super Damper
-18" MODA R6 wheels
$15,000
the951racer- Posts : 135
treborr likes this post
