Mon Jul 08, 2013 1:56 pm by Admin
LS Engine Install Question
Hey Guys,
Getting ready to do some test fitments of my L76 to check:
1. Pilot Bearing Engagement (without clutch installed)
2. Throwout bearing engagement/clearance (with clutch installed)
I currently have the transaxle installed. I am planning on test fitting without any accessories on the engine, and the bellhousing already bolted to the torque tube.
Is it possible to install with the transaxle already mounted? or is it necessary to drop to get the driveshaft alignment?
Appreciate any tips/advice.
Reed
Reed
rjarvis- Posts : 61
Re: LS Engine Install Question
You can do all of the checks with the transaxle installed. The clutch needs to be centered really well to get it to slip together for final assembly. If you have to, you will have to remove the transaxle to adjust the depth of the input shaft because you will have to slide it forward or backward in the torque tube housing. You can tap the shaft with a dead blow hammer to move it. You might have to modify the notch in the torque tube shaft to make the coupler align with the transaxle if you needed to move the shaft in the torque tube.
gwistrup- Posts : 113
Thanks gwistrup. All makes sense, hoping I don't have to adjust the torque tube shaft but we will see.
rjarvis- Posts : 61
» 1986 951 LS1 Conversion
» LS1 engine install help booklet
» Which engine version is easier to install and to get working
Yesterday at 10:16 pm by Ironworker613
Yesterday at 2:14 pm by SpeedRacer11
Yesterday at 1:30 pm by ThomasJoseph315
Thu Apr 25, 2024 8:12 am by Nath1142
Mon Apr 22, 2024 5:22 pm by lowform
Mon Apr 22, 2024 5:12 pm by lowform
Mon Apr 15, 2024 4:59 pm by JW1970
Mon Apr 15, 2024 7:51 am by Raymond-P
Fri Apr 12, 2024 1:07 pm by Rob44
Wed Apr 10, 2024 8:09 pm by LS982
