VSS install question
I am trying to install the VSS setup on my turbo trans that has an oil cooler. The oil cooler seem to be in the way if I try to install towards the bottom or front end of the trans. I found one spot which is above the oil pump where the Fuel pump cover sits. I will have to cut some of that cover to make it work.
I just wanted to know if anyone else has tried to install a VSS on a tranny with an oil cooler.
» Turbo Transaxle wanted
