C5 1 piece bellhousing adapter
+3
murrayg
knucklehead12
rjarvis
7 posters
Hey,
Was wondering if anyone had drawings for the 1 piece bellhousing adapter plate. I am planning to machine my own plate, but I can only find the drawings for what I'm assuming is the 2 piece bellhousing on the 944hybrids wiki.
Did the adapter thickness change from 0.6" when the 1 piece bellhousing became more common? Now that a spacer is required between the block and the bellhousing.
Appreciate any help.
rjarvis- Posts : 61
Re: C5 1 piece bellhousing adapter
I don't have any drawings but have one for sale if you need one. $75
knucklehead12- Posts : 50
Yes definitely interested . Don’t think I can on yet.
Do you know if any machining has to be done on the bell housing? Also do you have the spacers for the bell housing to block for sale?
rjarvis- Posts : 61
Meant to say don’t think I can pm yet
rjarvis- Posts : 61
just pm'd you
rjarvis- Posts : 61
Is it the same adapter as the two piece one, or is it thinner? Will the original adapter made for the 2 piece bell housing work with a 1 piece (auto) bell housing?
Gord.
Gord.
murrayg- Posts : 105
rjarvis likes this post
I’m looking for the C5 auto bellhousing adapter. Someone has one for sale? Or where can I order?
rock_with_david- Posts : 2
To use the 1 piece C5 automatic bell housing you need.
No the original C5 2 piece adapter plate will not work with the automatic bell housing.
Original C5 2 piece adapter plate will work with the 2 piece bell housing.
Texas Performance Concepts (i am the owner) sells the new C5 1 piece adapter plates and modified 1 piece bell housing with spacer.[/list]
- modified 1 piece bell housing for hydraulic lines
- 1/4 shim to install between the block and bell housing
- new 1 piece adapter plate, modified to use with the 1/4 spacer
Rich L. likes this post
knucklehead12 wrote:I don't have any drawings but have one for sale if you need one. $75
If rjarvis hasn't bought it, I'd be interested. I too can't pm yet.
tarmac terrorist- Posts : 3
He only has a Bell housing for sale
rjarvis- Posts : 61
» SOLD - Used C5 Adapter Plate for 2 piece bellhousing
» C5 Bellhousing Adapter Plates and Pilot Bearing Adapter Combo
» C5 Bellhousing Differences
