Power Steering Pump
Power Steering Pump
What pumps are you guys running with your swaps? I went with a cheap Cardone rebuilt in my LS3 swap w/ mustang hydroboost which whines like crazy and now seems to be leaking. Thinking of spending the money on a fresh GM oem pump this time around. Anyone have success with the stock GM pump? Seems many are running the Turn1 pumps. These are 500 bucks plus these days. Is this the only viable option with these swaps and the stock rack? I am aware of the pressure differences etc. But reading some earlier posts, seems some have had success with the stock Fbody pumps.
Leva- Posts : 82
Re: Power Steering Pump
I tried a stock LS1 pump with the Porsche steering rack but it didn't work out. The steering feel was off and the seals blew the first day out. This was without any hydro-boost, my brakes are manual. I then bought a Turn One pump and got a rebuilt rack, works perfect. YMMV
Bruce da moose likes this post
Thanks for the insight Rich. Anyone know of a way to modify a stock pump to accomodate the rack? Ultimately, it seems that is what Turn One is doing, considering their starting point is oem pumps.
Leva- Posts : 82
I always wondered if that pump would work. Its from a jeep with a hydraulic powered cooling fan. I'm not sure of its pressure and flow rates.
You could always add one of these to adjust the pressure
2002 wj jeep PUMP MOTOR SPECIFICATIONS 4.7L
ENGINE - RELIEF PRESSURE ± 50 - FLOW RATE (GPM)
4.7L ----9653 kPa (1900 psi) ---- 1100 RPM 2.4-2.8 GPM Minimum @ 200 psi
Interesting. Looks identical to the fbody pump. Wondering if anyone ever tried this. I remember this pump being mentioned somewhere in the forum before.
Leva- Posts : 82
Ya, the body of the pump should be the exact same. I think the porsche rack operates at 1800psi?? The jeep pump might be a good match for power steering and hydroboost
Leva wrote:What pumps are you guys running with your swaps? I went with a cheap Cardone rebuilt in my LS3 swap w/ mustang hydroboost which whines like crazy and now seems to be leaking. Thinking of spending the money on a fresh GM oem pump this time around. Anyone have success with the stock GM pump? Seems many are running the Turn1 pumps. These are 500 bucks plus these days. Is this the only viable option with these swaps and the stock rack? I am aware of the pressure differences etc. But reading some earlier posts, seems some have had success with the stock Fbody pumps.
Having built several of these cars for customers, I have learned the do's and don'ts. I don't use the stock GM pump any longer as I have had many that caused problems. I had 2 different cars that would boil the fluid out of the pump lid. At first I thought they were overheating, but it didn't really make sense. I added power steering coolers to both, which didn't help at all. Both of these were street cars only, with very mild built engines. I eventually changed to the turn1 pumps and had no more problems. I don't even try to use the stock pumps any longer. Plus the fact that stock gm pumps are getting very hard to find.
P/S pumps
Another thing to take into consideration is the poor quality of ANY remanufactured auto parts. It seems as though a good OEM recycled part is better than a remanufactured part. Even if the Jeep pump has better specs compared to the GM pump, how long will a remanufactured one last? If the Jeep pump is better, maybe an OEM one or a good used one would be worth a try.
I have the original GTO pump on my car and it seems to be working OK. It started to whine after I added a cooler. Weird.
Gil
Gil
gwistrup- Posts : 113
gwistrup wrote: Another thing to take into consideration is the poor quality of ANY remanufactured auto parts. It seems as though a good OEM recycled part is better than a remanufactured part. Even if the Jeep pump has better specs compared to the GM pump, how long will a remanufactured one last? If the Jeep pump is better, maybe an OEM one or a good used one would be worth a try.
Gil
Especially with Cardone reman parts. I refuse to use that brand for anything.
Yeah, I keep learning my lesson with the Cardone parts. But sometimes its the only choice available and hit or miss.
I know i did not do myself any favors cheaping out on a rebuild. Now i need to decide if im going to gamble on a better oem or take the plunge with a turn 1 and hopefully be done
Leva- Posts : 82
Leva wrote:Yeah, I keep learning my lesson with the Cardone parts. But sometimes its the only choice available and hit or miss.
This is a brand new GM pump for sale on ebay.
There's also this pump, but you'd have to source an Fbody reservoir to make it work correctly
A stock f body pump will probably just continue to boil the fluid. The porsche rack wants a higher pressure than the pump can handle and will run the fluid thru the relief valve of the pump and heat it up. I'd try a junkyard wj jeep pump and see what happens.
» LS1 Power Steering Pump Delete Questions? belts, pullies, w/o GM pump?
» Turn one power steering pump.
