Yesterday at 9:03 am by chrenan
Fri May 25, 2018 8:34 pm by superman22x
» WTB: 944 Turbo Roller
Thu May 24, 2018 8:32 pm by knight76
Thu May 24, 2018 7:52 pm by matt889
» New here needing help
Thu May 24, 2018 3:45 pm by sharkey
» 5.3 conversion on 88 Turbo
Wed May 23, 2018 11:00 am by kevin924kevin
Tue May 22, 2018 10:36 pm by mryan318
» Clutch Issues - HELP!!!
May 2018
78910111213
14151617181920
21222324252627
28293031
Turn one power steering pump.
Post  fliermike45 on Tue Jan 11, 2011 12:11 pm
I am using a Turn One LS1 PS pump, in talking to their tech guru he advised that I check with other users what orifice size they used and whether they used a cooler.
1. What Orifice size (in the outlet fitting) is realistic for road use?
2. Is it necessary to use the cooler array for road use?
Thanks, Mike
Re: Turn one power steering pump.
Post  docwyte on Tue Jan 11, 2011 4:13 pm
I'm using a cooler, not sure what orifice size. I just told him I was using it with the 944 rack and he did his thing.
I wouldn't run this without a cooler, but I'm also running hydroboost brakes and track the car regularly.
Post  Bluemach1 on Tue Jan 11, 2011 7:59 pm
funny, when I spoke with them before buying mine, I was told that the unit they are selling as the "944" pump was based on the specifications of a 944 conversionist (TonyG I think). I was told that they had no idea what the pressure needed to be and did not seem too concerned about figureing it out.
Bluemach1
Post  Vorsche944 on Tue Jan 11, 2011 8:36 pm
I have the Turn 1, Hydroboost, PS Rack, filter and run with a cooler. I run street. I do not know what the orafice is.
I concur with DocW. Run it with a cooler.
Vorsche944
PS Pump
Post  fliermike45 on Wed Jan 12, 2011 8:40 am
The Guru suggests using the smallest orifice and test drive, if there is any hesitation of "hanging" of the steering then increase the orifice for more flow.
Anybody experienced the hesitation?
Post  944convert on Wed Jan 12, 2011 5:26 pm
fyi...the 944 ps pump is rated at 110 bar to 120 bar (1600 PSI to 1740 PSI)
Post  sbwrench on Wed Jan 12, 2011 6:16 pm
I got the first turn one pump and worked with them on the pump specs. They always forget when a Porsche guy calls! Tell Jeff, I think thats the owner, to look up the specs on LUDINGTON. I'm going on three years with mine. A little noisy but it works great.
sbwrench
