Help with Vaccum Lines
Can someone help me with where these should be connect.
Red944ls1- Posts : 98
re: vacuum lines
Number 1 should be connected to the canister purge solenoid for the EVAP system. Number 1 is a non-ported vacuum source that you can block off if you wish. Numbers 2 and 3 are for the "Clean side" of the PCV system. Usually they are connected together. The stock LS1 PCV system has rigid plastic hoses and some other items to connect both valve covers. There are several threads on this forum on the topic of PCV systems and catch cans. Good luck, Gil
gwistrup- Posts : 113
Red944ls1 and smkn951 like this post
Re: Help with Vaccum Lines
Thanks for the info. I got things hooked up and all is running better.
The o2 and fuel is in limits
» Vaccum lines with no emissions
» Heat sleeving for remote oil lines and coolant lines
» AC fittings.
» AC fittings.
