Coil mounting pictures
I need to relocate the rear coils on the driver side to clear the hydroboost. The engine I am using is a LM4 5.3 aluminum TrailBlazer engine so it had metal brackets attached to the valve covers to mount the coils. I would like to keep the coils on the engine if possible. Is there an aftermarket kit to relocate the coils closer to the fuel rail? Or could anyone please show a picture of how you relocated your coils?
Thank you, Gil.
Thank you, Gil.
gwistrup- Posts : 113
Re: Coil mounting pictures
I know you said you wanted to keep them on the engine, but this is just some food for thought.
87944turbo- Posts : 76
Coil wires
Did you have issues with routing the plug wires? I would like to keep the stock hood latch and put the air cleaner under the header panel too.
Plug wire routing was pretty straight forward. Does require long wires. These were built from a kit I believe. I had to cut out the stock hood latch. Went with Aerocatch latches.
Mine will eventually be rerouted to reach to the section right between the intake and firewall, whenever I decide I want to risk my harness. In the meantime, they are ziptied haphazardly to a janky bracket and my brake master cylinder
Kiltacular Jim- Posts : 15
kevin924kevin- Posts : 927
Coil mounting
Looks good. I have the truck style coils but your installation gives me some ideas on how to stack the coils. Thank you.
» Can anyone post up some clear pictures of relocated coil packs?
» WTB Coil Over Springs
» Truck coil covers
» Truck coil covers
Today at 12:39 pm by Nath1142
