suspension setup help please
Hello guys,
I actually made it out this weekend for auto X and a few laps around a road course and I ran into a few issues.
First my car is a 1983 944 with a Ls swap and a turbo. The car sits a little lower in the front after the swap and a little to high in the rear. On the track it has way to much body roll to corner fast and in return looses traction at times.
This winter I would like to overhaul the suspension, brake system trans and axles. I see many put stiffer springs up front but not many talk about the rear. Not sure if I should keep the torsion bar and reindex it or just go to coil overs in the rear? Any input on a good setup that will work on some street use and some track use?
It is embarrassing that I can kill most the cars on the straights and I get passed in a matter of a couple tight corners.
If you have input on a setup please let me know where you found these parts for a decent price.
Josh
Josh
Last edited by yamamtx on Sun Sep 10, 2017 8:00 pm; edited 1 time in total (Reason for editing : changing my name to not having my last name on the post)
yamamtx- Posts : 97
Re: suspension setup help please
It is an iron block with the turbo mounted where the passenger headlight would normally be.
The car weighs 2850 with about a half tank of fuel.
yamamtx- Posts : 97
I would probably use a 500# spring in the front. That should give you a fair balance between AutoX and track driving and still make it tolerable on the street. If you plan to do more track driving, then maybe 700# might be a better choice.
The rear is much easier to deal with after a coil-over conversion. I would suggest it if you plan to work with your suspension setup more than once.
Do you have any info on the coil over conversion?
Pictures?
Products used?
I haven't seen much on this so I'm a bit lost when it comes to the rear suspension conversions.
Thanks for the help
Pictures?
Products used?
Thanks for the help
yamamtx- Posts : 97
Check out Ground Control. They sell a Koni set-up and you can spec. your own spring rates.
Also, being that you have an early car, you could swap out the inserts and convert the stock strut bodies to use the adjustable perch. Paragon has all the goods to make this happen.
You can find just about any information you desire about P-cars on the Rennlist.com forum. Check there for suspension deets.
» Need suggestions on what else to add to my suspension
» Need help with suspension
» Suspension and brakes
Yesterday at 3:06 pm by Rob44
