91 S2 suspension
+3
money pit 951
Hotrodz of Dallas
7 posters
91 S2 suspension
I have changed out my 924 to 91 S2. I have new steel front arms. Will i use new or old offset for my wheels? I saw a post here once that showed a conversion to lengthen the steel arms. Is this needed?
kevin924kevin- Posts : 927
Re: 91 S2 suspension
kevin924kevin wrote:I have changed out my 924 to 91 S2. I have new steel front arms. Will i use new or old offset for my wheels? I saw a post here once that showed a conversion to lengthen the steel arms. Is this needed?
If you are still using the steel arms then you will use the early offset. As weak as the steel arms are, I would upgrade to the aluminum ones. You can use early or late arms depending on what offset wheels you want to use. Plus with the aluminum arms you use a bolt on rear bushing instead of the press on rubber one.
Yes they are a little weaker, but mine will be reinforced around the edge and i love the easy ball joint replacement. All in brand new form ball joints to racing bushings. I looked at the alum way back and decided the steel is better when they are reinforced at the edges. My opinion. Thanks for the response.
I believe the S2 was also an early offset car.
money pit 951- Posts : 101
Nope, all S2's are late offset. In fact all 944 87 and newer are "late offset.
Gord.
murrayg- Posts : 105
Thank you all for the replys.
Hi Kevin,
Can you post some pictures of how you plan to strengthen the steel front control arms. I to have these and curious on exactly what you plan to do to strengthen them.
Justin
Justin
Jchard944- Posts : 96
You are very welcome.
Jchard944 wrote:Hi Kevin,
Justin
When I use to track an early 924 I'd have someone seam weld the steel control arms. Not a continuous bead, but a bead a couple of inches long every couple of inches along the manufacturing seam of the control arm, if that makes sense. Some folks will box them in with plate instead.
chrenan- Posts : 203
Hi Justin, i plan to box them in. A thin piece of flat iron fit to sit just inside the arm perimeter. Stitch weld in place, and good to go. I think i will also have the area where the sway bar fastens re inforced. I have heard of them wearing out at that point. But my 78 924 had 110000 miles on it when i parked it and all the front end parts are really nice and tight. In saying that i am still going to change out ball joints bushings etc so its all new. My a arms are brand new with the the derelin bushings and ball joints. i am debating doing the ball joint extension but no criticale, early offset front and later rear. This can be dealt with, with the rims.
Thanks for the reply. I just purchased all new control arms with polyurethane bushings as well as new tie rods. Need to figure out sway bar bushing size when time comes. But thanks for the help makes sense now.
happy to help. I have had many members help guide me and it is always very appreciated.
I thought the control arms were interchangeable and the spindles, hubs and struts changed the offset.
racertomtom- Posts : 144
racertomtom wrote:I thought the control arms were interchangeable and the spindles, hubs and struts changed the offset.
They are interchangeable, but the arms are different lengths.
Today at 12:47 am by sharkey
