Holley intake, vacuum pump and cross member spacer EmptyToday at 7:08 am by gwistrup
Holley intake, vacuum pump and cross member spacer EmptyYesterday at 10:12 am by Nath1142
Holley intake, vacuum pump and cross member spacer EmptyMon Apr 22, 2024 7:22 pm by lowform
Holley intake, vacuum pump and cross member spacer EmptyMon Apr 22, 2024 7:12 pm by lowform
Holley intake, vacuum pump and cross member spacer EmptyMon Apr 15, 2024 7:28 pm by JW1970
Holley intake, vacuum pump and cross member spacer EmptyMon Apr 15, 2024 6:59 pm by JW1970
Holley intake, vacuum pump and cross member spacer EmptyMon Apr 15, 2024 9:51 am by Raymond-P
Holley intake, vacuum pump and cross member spacer EmptyFri Apr 12, 2024 3:07 pm by Rob44
Holley intake, vacuum pump and cross member spacer EmptyWed Apr 10, 2024 10:09 pm by LS982
Holley intake, vacuum pump and cross member spacer EmptyTue Apr 09, 2024 1:54 am by lowform
Holley intake, vacuum pump and cross member spacer Empty Holley intake, vacuum pump and cross member spacer
Post  spoon4364 Mon Jul 31, 2017 2:54 pm
Ok, I purchased the Holley EFI sniper 102mm intake. From what I've gathered, the cross member spacers are to help the intake clear the hood, correct? I went with this one because it'll be good for my 7k power band, as well as almost 2" shorter than stock!! By the time intake, TB, and fuel rails are purchased, I'm at $800 vs the $1,300 for the Fast LSX. So do I need the spacers still?
EDIT: Added to main title. Also curious on the hydroboost system. I work at GMC, and I'm wondering why no one uses the electric vacuum pump vs a hydroboost. The Camaro, CTS-V, and Corvette all run an electric vacuum pump. Its less parts to deal with, and I think it will aid in better clearance.
spoon4364
Holley intake, vacuum pump and cross member spacer Empty Re: Holley intake, vacuum pump and cross member spacer
Post  sharkey Mon Jul 31, 2017 6:29 pm
the primary reason for the spacers is hood clearance, however ive also heard of clearance issues around the master cylinder or hydroboost that the spacers also take care of.
Post  docwyte Tue Aug 01, 2017 8:05 am
The spacers are mostly for throttle body clearance. Even with the spacers, I still had to cut some off my throttle body and notch the hood support....
Post  spoon4364 Tue Aug 01, 2017 9:54 am
docwyte wrote:The spacers are mostly for throttle body clearance.  Even with the spacers, I still had to cut some off my throttle body and notch the hood support....
Ok, so the spacers are 1/2". Since this intake is 1.8" shorter, than I should be good to go, and also wont have the bump steer spacers problems. Right?
spoon4364
Post  docwyte Tue Aug 01, 2017 10:00 am
The clearance on the stock intake isn't the problem. It's the throttle body that hits. So just because that Holley intake is shorter doesn't mean you won't have clearance issues....
Post  sharkey Tue Aug 01, 2017 12:05 pm
spoon4364 wrote:EDIT: Added to main title. Also curious on the hydroboost system. I work at GMC, and I'm wondering why no one uses the electric vacuum pump vs a hydroboost. The Camaro, CTS-V, and Corvette all run an electric vacuum pump. Its less parts to deal with, and I think it will aid in better clearance.
hydroboost isnt used because the ls engines down produce enough vacuum, its used because there is no room in the engine bay for a vacuum booster with a v8 swap. hydroboost is significantly smaller.
Post  Hotrodz of Dallas Fri Aug 04, 2017 11:54 am
spoon4364 wrote:Ok, I purchased the Holley EFI sniper 102mm intake. From what I've gathered, the cross member spacers are to help the intake clear the hood, correct? I went with this one because it'll be good for my 7k power band, as well as almost 2" shorter than stock!! By the time intake, TB, and fuel rails are purchased, I'm at $800 vs the $1,300 for the Fast LSX. So do I need the spacers still?
Not trying to start an argument or anything, but this intake is 1.875" shorter than Holley's normal sniper intake. It's still about 1" taller than a stock LS intake.
Hotrodz of Dallas
Hotrodz of Dallas
Post  zeusrotty Sun Aug 13, 2017 12:33 am
Having the spacers in isn't a bad thing. It drops the motor that much more which helps handling because the weight is lower. This is a spot you don't want to reinvent the wheel on.
zeusrotty
