» Transaxle rebuild
» Hello, Gentlemen.
Yesterday at 7:43 pm by rawr
» alignment specs
how much to cut cross member?
Post  murrayg on Wed Mar 26, 2014 11:01 am
Hi all,
I'm about to install my crossmember to the motor for the first time.  The motor is just about finished and still on the stand.  The crossmember isn't even close to fitting over the oilpan.  Are there any photos of crossmembers that have been trimmed on line, I couldn't find any?  Have I done something wrong?  Just getting going with this swap, I'm sure I'll have more questions!
murrayg
Re: how much to cut cross member?
Post  Rich L. on Wed Mar 26, 2014 1:50 pm
It's pretty easy to get the motor mounts reversed, left one on the right side. It can seem correct but makes the oil pan come nowhere near fitting.
Post  murrayg on Wed Mar 26, 2014 7:14 pm
Anyone have pictures of how they cut the crossmember for oil pan clearance? Also, any shots of the mounts installed would be cool too.
murrayg
Post  99sierra4x4 on Wed Mar 26, 2014 8:16 pm
I will try to find a picture, but I did not cut my cross member at all, I actually clearanced my oil pan. I don't think anyone around here is clearancing the cross member, but I could be wrong.
Andy
99sierra4x4
Post  RS Technic on Wed Mar 26, 2014 9:33 pm
Here is a side rear pic of mine...
this is with Eric's pan and mounts.
They aren't perfect pics of just the pan and mounts but they should help.
RS Technic
Post  Tehone on Wed Mar 26, 2014 10:19 pm
Not sure you can see much but I can't find any better photos of the mount
The right side of the photo is cut off so you need to save it to your PC and then it should be full size.
the top of the rack mount is all I know of being cut down some to get clearance in this area. Others have placed spacers under the TPC mounts to get the clearance.  I have a power rack and cut down some on this mount but I don't have it in the car to provide positive testimony.  I think I will still be looking at adding 1/4" spacers but then there is the need to watch for the hood clearance to throttle body.
Have fun and enjoy
Tehone
